Replacement Shower Escutcheon - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-27-2011, 09:12 PM   #1
I want to replace the shower escutcheon since the chrome is peeling and I hope someone can help with a part number. The shower faucet is made by Moen and the plastic handle indicates it is the Chateau series. The outside diameter of the plate is 7". The mounting holes are at 5 and 7 o'clock. The diameter of the hole for the valve is approximately 1 1/8". The center to center distance between the mounting holes is also about 1 1/8". Stanadyne is stamped on the front between the two mounting holes. The shower was installed around 1986. I'm sure it was a standard contractor grade used in residential developments. Is this enough information to identify the correct replacement part?
Thanks,
David
Jessidog is offline   Reply With Quote
Old 11-27-2011, 09:19 PM   #2
Rewards Points: 582
check to see if there is a moen dealer in your area...if not check local h.d or lowes to see if they handle moen.....could check on line www.moen.com... ben
Old 11-27-2011, 09:26 PM   #3
I've been checking for Moen replacement parts online. The difficulty has been finding dimensional drawings. I've found several different Moen escutcheons that look similar in the drawings, but the dimensions of the mounting holes, center hole, etc. are not provided.
David
Old 11-27-2011, 09:35 PM   #4
Rewards Points: 582
call moen 1-800-289-6636 give them infor you posted ..Iam sure they will help..ben hey david the part you are looking for is diverter trim plate...
The Following User Says Thank You to ben's plumbing For This Useful Post:
Jessidog (11-27-2011)
Shower Arm Replacement - Please Help Detroitphan Plumbing 7 03-06-2011 11:52 PM
Price Pfister 3 Valve Shower Replacement water issue LeviDIY Plumbing 3 06-18-2009 02:59 PM
Bathroom Shower Window Replacement Question Jonnyonthespot Kitchen & Bath Remodeling 6 06-15-2009 12:54 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 11:42 AM
Shower Fixture Replacement shapeshifter Plumbing 12 02-20-2007 08:21 PM
