Replacement Shower Door Hinges - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-01-2011, 10:07 AM   #1
The lower hinge broke loose on our shower door. It looks like it might be quite an old door because I can't see any similar hinges at the usual stores where such things might be sold. The hinges are going to be hard to remove because both of the screws fixing them are stripped badly and it looks like Ill have to drill them out. I would like to remove the hinges and replace with identical ones if possible. Failing that I need to find a hinge design which will work with the holes already bored in the glass door. Or is it easy to drill new holes for a different hinge design?
Does anyone know where to obtain the hinge shown below? Or have any suggestion of what other hinge design I could use to repair this door. It is a framed shower design and the hinge fits onto a metal strip which slides into the shower frame. I can buy a different strip design if need be.
imaginarctic is offline   Reply With Quote
Old 11-27-2012, 05:01 PM   #2
Did you ever get a reply to where to find this hinge? I have the same exact hinge that broke on me. I'm in Southern California also.
djm1965 is offline   Reply With Quote
Old 11-27-2012, 08:02 PM   #3
Rewards Points: 13,712
http://www.bing.com/images/search?q=...nges&FORM=IGRE
Old 11-27-2012, 10:46 PM   #4
did you try a glass place that does tub and shower enclosures?
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 09:00 PM
Price-phister Shower hot side two valve O-Ring replacement? Bozohelp Plumbing 11 06-14-2011 04:44 PM
shower and bath fixture replacement advice billyg Plumbing 0 01-25-2011 01:37 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Shower mixing valve replacement w/galvanized pipe rsaritzky Plumbing 3 05-13-2009 10:11 AM
