Replacement For Leaking Shower Arm? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-24-2011, 10:41 AM   #1
replacement for leaking shower arm?
I have a 10" wingnut adjustable shower arm in one bathroom, and it has sprung leaks from both joints. I'm guessing it's a couple years old. One of the metal cup-shaped escutchon washers has a small divot at the edge (this joint leaks the worst). The shower head is just a nozzle - nothing heavy. It leaks no matter how hard the wingnuts are tightened.
A little research revealed that this design (AquaFlux & others) is prone to leaks after a year or so. Lowe's sells a rebuild kit, but I'm wondering if the design is flawed, and ,no matter what brand you get, you're going to get leaks after a year.
Thanks much.
SixStrRzr is offline   Reply With Quote
Old 03-24-2011, 01:05 PM   #2
Rewards Points: 1,578
PErhaps you could replace the o-rings in the joint (if it has o-rings)? Might get some plumber's silicone grease and smear some on the mating surface when you reinstall. Might last longer. Cheaper than a new arm I'd bet and especially if it works.
bob22 is offline   Reply With Quote
Shower Arm Replacement - Please Help Detroitphan Plumbing 7 03-06-2011 10:52 PM
shower and bath fixture replacement advice billyg Plumbing 0 01-25-2011 01:37 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Shower head replacement zachg Plumbing 10 01-24-2010 08:21 PM
Shower mixing valve replacement w/galvanized pipe rsaritzky Plumbing 3 05-13-2009 10:11 AM
