Replacement Garbage Disposal Drain Pipe Stuck! - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-11-2012, 08:44 PM   #1
replacement garbage disposal drain pipe stuck!
Removed my old ISE disposal today, but can't get the black downpipe/drainpipe out of the fitting.
i tried gently wiggling, rocking etc etc, but it wont come out. is there any tool to help it out? i'm worried that the previous installer glued it in. if they did glue it in, do i need to hack it off? oh brother...
any help/ideas would be great. fyi, the new disposal wont fit the existing fitting. i prayed, but that wasn't enough.
first pic is the black exit pipe that was attached to the disposal, 2nd pic just a back up to reference the entire plumbing job.
thanks again
dave
replacement garbage disposal drain pipe stuck!-imag1572.jpg   replacement garbage disposal drain pipe stuck!-imag1574.jpg
thundercracker is offline   Reply With Quote
Old 11-11-2012, 08:52 PM   #2
DIY Enthusiast
sublime2's Avatar
Whoever did that pluming cemented those pipes in place. That's why it won't move.
Maybe cut the pipe below the "T" and replace it with a compression "T" compatible with the other pipe size.
sublime2 is offline   Reply With Quote
Old 11-11-2012, 08:58 PM   #3
agh! my worst nightmare. cemented me in! thanks for confirming my thoughts. at least it's not a case of me being too weak.
The Following User Says Thank You to thundercracker For This Useful Post:
ben's plumbing (11-11-2012)
Old 11-11-2012, 10:58 PM   #4
Rewards Points: 352
Try penetrating oil and a heat gun.
plumberinlaw is offline   Reply With Quote
Old 11-11-2012, 11:05 PM   #5
DIY Enthusiast
sublime2's Avatar
Actually looking again I would cut it all out to the main and replace it with all compression fittings.
Presently if your trap clogs you can't remove it to clean it.
Old 11-12-2012, 06:14 AM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
That trap has a clean out on the bottom.
Use a large pair of channel-locks to twist that black disposer tail piece out. I doubt it is cemented. The get stuck from water deposit build up.
Coastal South Carolina
Old 11-12-2012, 06:35 AM   #7
Rewards Points: 436
I'm seeing threads and a compression nut. Twist it but with a back up.
Old 11-16-2012, 10:24 AM   #8
thanks for all the replies. lucked out and found a plumber, who's the husband of our babysitter. he came in, couldnt get the tube out either, hacked off some fittings, installed a new p-trap and 60 minutes later, i was garberating the old pvc pieces.
Tags
drain pipe , garbage disposal , plumbing
2" drain in sink for garbage disposal? robhag Plumbing 8 04-25-2012 09:54 AM
Need to close off or move a vent pipe & drain that goes to nothing mystic_cobra Plumbing 2 04-18-2011 09:14 PM
Water leaking from under disposal/Installing new disposal quadari Plumbing 6 06-29-2010 12:39 PM
Replacement Garbage Disposal lvrollers Plumbing 9 10-11-2008 09:50 PM
DIY Garbage Disposal replacement bigbob Plumbing 1 06-07-2006 07:05 PM
