-   -   replacement garbage disposal drain pipe stuck! (http://www.diychatroom.com/f7/replacement-garbage-disposal-drain-pipe-stuck-163004/)
thundercracker 11-11-2012 08:44 PM
2 Attachment(s)
Removed my old ISE disposal today, but can't get the black downpipe/drainpipe out of the fitting.
i tried gently wiggling, rocking etc etc, but it wont come out. is there any tool to help it out? i'm worried that the previous installer glued it in. if they did glue it in, do i need to hack it off? oh brother...
any help/ideas would be great. fyi, the new disposal wont fit the existing fitting. i prayed, but that wasn't enough.
first pic is the black exit pipe that was attached to the disposal, 2nd pic just a back up to reference the entire plumbing job.
thanks again
dave
sublime2 11-11-2012 08:52 PM
Whoever did that pluming cemented those pipes in place. That's why it won't move.
Maybe cut the pipe below the "T" and replace it with a compression "T" compatible with the other pipe size.
thundercracker 11-11-2012 08:58 PM
agh! my worst nightmare. cemented me in! thanks for confirming my thoughts. at least it's not a case of me being too weak.
plumberinlaw 11-11-2012 10:58 PM
Try penetrating oil and a heat gun.
sublime2 11-11-2012 11:05 PM
Actually looking again I would cut it all out to the main and replace it with all compression fittings.
Presently if your trap clogs you can't remove it to clean it.
rjniles 11-12-2012 06:14 AM
That trap has a clean out on the bottom.
Use a large pair of channel-locks to twist that black disposer tail piece out. I doubt it is cemented. The get stuck from water deposit build up.
SeniorSitizen 11-12-2012 06:35 AM
I'm seeing threads and a compression nut. Twist it but with a back up.
thundercracker 11-16-2012 10:24 AM
thanks for all the replies. lucked out and found a plumber, who's the husband of our babysitter. he came in, couldnt get the tube out either, hacked off some fittings, installed a new p-trap and 60 minutes later, i was garberating the old pvc pieces.
