Replaced Kitchen Sink Pipe - Still Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-16-2013, 11:37 PM   #16
Rewards Points: 12,808
Do yourself a favor and also get rid of the disposal. One of the most useless devices I've ever seen. Oh well there's also an electric can opener.
Old 02-21-2013, 10:38 PM   #17
hey, if not for the electric can opener I would never see my cat
paintdrying is offline   Reply With Quote
Old 02-22-2013, 07:47 AM   #18
We have dogs, funny how when you call there name they ignore you but let that micowave or oven timer go off and here they come.
Old 02-22-2013, 03:18 PM   #19
Building tradesman
Extension cord?
Am I mistaken or is the supply for that disposal an extension chord? If so needs to be redone with proper electrical. NEC allows 3' for a garbage disposal power supply. By plugging into an extension cord your length is increased by the length of that cord. A disposal is sometimes wired to the same circuit as a dishwasher, but usually is expected to be on a dedicated circuit. It should as a minimum have a 15 amp circuit with nothing else on it. Do yourself a favor and run #12 wire for the circuit to a single receptacle. If over a basement or crawl space use a surface box extended thru floor with emt and proper fiitting for simplicity. What you have is a no no.
PS installations like this are what insurance adjusters look for if there is a fire and even though it may not be the cause it makes the issue illegal undocumented installations. Permit is the law, but your choice, however the work should be up to code no matter what.
dudleydoright is offline   Reply With Quote
Urgent help need - Kitchen sink valve leaking Andee77 Plumbing 1 02-11-2013 12:40 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 12:33 PM
Kitchen Sink Flange Pipe jburchill Plumbing 3 03-21-2012 05:45 PM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 10:41 AM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 07:38 AM
