Replaced Kitchen Sink Pipe - Still Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-16-2013, 05:33 PM   #1
Hello-
I just tore out all the prior PVC pipes under my sinks as they were leaking.
I replaced the faucet as well as installed a garbage disposal. My hangup is I have never done this before and the PVC pipes are leaking. I applied sealant and it still leaks. I have added a pic. Any help would be appreciated.
Thanks.
phillysfinest4 is offline   Reply With Quote
Old 02-16-2013, 05:38 PM   #2
Civil Engineer
Rewards Points: 4,944
I have no idea what that grey stuff is, totally unnecessary if you get the pieces properly aligned, and use the correct gaskets. My guess is you have the wrong pieces. There are plastic gaskets that must be used in each connection. There are at least two sizes, depending on the type of pipe you are connecting to. Go to a plumbing supply store, they will have the right pieces. Show them what you need to connect, they will get you the right parts. And make sure the pieces align properly, you can get a leak if the pipes you are connecting are not straight.
Old 02-16-2013, 05:42 PM   #3
Rewards Points: 14,310
All the wrong fittings, and ran wrong. Toss all that and redo it something like this.
http://www.bing.com/images/search?q=...electedIndex=0
Dave Sal (02-17-2013)
Old 02-16-2013, 05:44 PM   #4
Roofmaster
Rewards Points: 2,210
Call a real plumber, please. No vent, Illegal trap that will siphon.
Old 02-16-2013, 05:52 PM   #5
I know it looks worse with all that gray stuff around it. I really don't have the money for a plumber. I just am not sure what exact pieces to get, like the connectors. The job before me was even worse. If anyone has like a link to the parts i need, thanks guys
Old 02-16-2013, 06:24 PM   #6
DIY staff
Rewards Points: 7,174
Post one more picture from a little further back--If we can see the pipe from the bottom of the cabinet--someone can help---
All that you have there is going to need to be replaced.
Old 02-16-2013, 06:52 PM   #7
yeah i dont care about buying a few new parts, thats fine
attached is the pic u requested
thank you
Old 02-16-2013, 07:20 PM   #8
DIY staff
Ready to start over?
You will need the following---about 3 feet of 1 1/2'' pvc pipe--a sanitary T- a 45* street elbow.--a threaded female adapter --an AAV--(Air Admitance valve) and a trap adapter.
First thing---remove all existing drain piping---leave the rubber fitting at the floor---
1--install a new P-trap to the garbage disposer---be sure you put the nylon washer on correctly--wide side to the nut--thin side to the fitting---
2 Loosen the disposer just enough that you can turn it ---
3 temporarily put the trap adapter and sanitary T onto the P-trap arm---swing the assembly so it is over the pipe in the bottom of the cabinet.( you may need to turn the disposer to get the aim right)
4 cut and install a section of pipe from the rubber boot to the bottom of the sanitary T---
5-add a section of pipe to the top of the T--with the female addapter and AAV attached---you want this as close to the bottom of the counter top as you can--
If everything fits---prime and glue using the proper stuff for PVC.--Tighten up the compression nuts on the P-trap---tighten up the disposer.
ben's plumbing (02-16-2013)
Old 02-16-2013, 07:22 PM   #9
this is what i need, i'll have to google what some of your terminology is, but thanks for your help, much appreciated
Old 02-16-2013, 07:54 PM   #10
DIY staff
In a nut shell---you need a drain straight up from the rubber boot---to a T--then up to a vent-(AAV)
Always put the P-trap on to the disposer first----that's how you know where the T- needs to be--and how it must face for the P=trap to enter it.
Old 02-16-2013, 07:58 PM   #11
THats Mike for you.
Clear and easy to understand directions without making one feel like a dufus
Thanks Mike
creeper is offline   Reply With Quote
Old 02-16-2013, 08:12 PM   #12
Another thing I noticed is the bigbox parts have become nothing but unusable. I would only use parts from a supply house, here at least they are much cheaper than a big box.
paintdrying is offline   Reply With Quote
Old 02-16-2013, 08:27 PM   #13
DIY staff
Originally Posted by creeper View Post
THats Mike for you.
Thanks Mike
Thanks Creeper----we all have strengths and weaknesses---
I can't figure out computers----I could carve one out of wood--but I can't post a picture---go figure---I would like to see a picture of a windmill---
Old 02-16-2013, 08:37 PM   #14
There you go.
What a coincidence. Someone very special recently shared this one with me
Old 02-16-2013, 09:16 PM   #15
Plumber
TheEplumber's Avatar
Rewards Points: 904
This is pretty much what mike described- but instead of the sink tailpiece, you have the disposal. Oh, and throw away the caulky stuff
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (02-16-2013), oh'mike (02-16-2013)
Urgent help need - Kitchen sink valve leaking Andee77 Plumbing 1 02-11-2013 11:40 AM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
Kitchen Sink Flange Pipe jburchill Plumbing 3 03-21-2012 04:45 PM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
