Old 02-23-2010, 01:58 PM   #1
Replaced Faucet. Now water smells of plumbers putty!
Replaced a Kitchen faucet which was over 12 yrs old I'm assuming. The sink has three holes. I got a $78 Glacier bay retractable faucet. It had a base which covered up the two side holes leaving the center open. They suggested using plumbers putty around the big screws which go into those two holes and the base can be screwed from underneath the sink. That's exactly what I did.
I led the water lines through the center hole, connected to the existing old water lines. Yeah, I had purchased new ones to replace the old water lines. But try as I might, I could not unscrew the old ones. I was about to call a plumber but figured out how to use the old ones.
The first time you turn on the water, it smells of plumbers putty. I have no idea how thats happening. If you let the water run for a few seconds, the smell goes away. Any idea how the water smells of the putty? How can I make it go away? Is it a bad faucet?
thanks!
Sam
emperor_black is offline   Reply With Quote
Old 02-23-2010, 04:21 PM   #2
Bump before I decide to take everything out.
Old 02-23-2010, 05:01 PM   #3
Newbie Bill
I too am confused why the water smells like plumbers putty as it doesn't sound like you put it inside the water lines?
Is it in fact the water that smells like plumbers putty or just the general sink area? Maybe running the water disipates the odor in the area.
I would leave it for a bit longer if possible to see if problem continues. But I am not an expert.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 02-23-2010, 06:30 PM   #4
the water was fine before the new faucet. Actually very tasty water in San Jose, CA. Even now, after running it for a few seconds, its fine. But the first drink, it tastes horrible and smells of putty.
Old 02-23-2010, 08:12 PM   #5
Household Handyman
I've had this smell hang around for a few weeks after installing a new faucet. IMO--it may be that the smell is in the general area, and running the water changes your "smeller" over. before I would take out anything I would give it more time.
Old 02-23-2010, 08:14 PM   #6
Xtreme DIY'r
Possibly when you fed the pipes thru the holes you hit the putty
But sounds like you removed the new feeds & re-used the old ?
Maybe still smeared some on the pipes ?
Old 02-23-2010, 09:30 PM   #7
I cleaned out the holes completely of all the old putty. I could not remove the old lines. I connected the old lines to the faucet's lines. Other than the screw base that holds the faucet's base, there's no putty anywhere.
however, i do have another doubt. Other than the two water lines, the faucet had a plastic pipe to which I connected the long hose that holds the retractable faucet's spray. Could the putty smell be getting to that plastic pipe somehow?
Old 02-23-2010, 09:43 PM   #8
concretemasonry's Avatar
Run the hot water for a few minutes and then take a sample to smell and taste. Do the same with the cold water.
The hot water should clean the plumber dope out much quicker since it will dissolve most things faster..
Your sense of smell can easily be more discerning than taste and the odors can carry over before you even taste.
Dick
concretemasonry is offline   Reply With Quote
Old 02-23-2010, 11:09 PM   #9
Doing it myself
Alan's Avatar
Glacier Bay....
Clear the bridge!!!! Dive Dive Dive!!!
Journeyman Plumber
Old 02-25-2010, 03:33 PM   #10
Maybe there were some oils or residues inside the tubing and channels inside the faucet assembly, left behind after the manufacturing process.
This should dissipate after a few on-off usages with hot water.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 03-04-2010, 09:19 PM   #11
Its almost two weeks now and the smell is almost gone. Only when I turn it on the very first time in the morning, there is a smell. But its nowhere that strong and I'm not gonna worry about it anymore.
Even though the putty is only at the base, the base of the faucet itself is hollow which means some smell can get into the faucet itself and when the first water comes out, it carries the smell along with it. That's my best take on the situation.
this thread can be closed. Thanks everyone!
The Following User Says Thank You to emperor_black For This Useful Post:
drtbk4ever (03-04-2010)
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 06:10 AM
Low hot water pressure on kitchen faucet KE2KB Plumbing 7 12-19-2008 10:49 AM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 11:24 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
