Replaced 12amp Sump Pump Switch With 15amp Switch? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-11-2013, 02:16 PM   #1
Rewards Points: 18
Replaced 12amp sump pump switch with 15amp switch?
The float switch blew on my 1/2 hp sump switch and the only replacement switch I could find was for a 3/4 hp sump pump. The new switch fits perfectly but its rated 15a instead of the original 12a switch. My question is, this should work fine right? There is no fuse built into the switch or anything right?
I'm thinking that the new switch is simply rated for a higher draw and it will simply be underutilized. Anyone here know for sure?
chaz7979 is offline   Reply With Quote
Old 03-11-2013, 03:12 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,730
Ayuh,.... Yer Right, No problem...
Old 03-11-2013, 03:38 PM   #3
Rewards Points: 18
Thanks for verifying. Great news.
Paid $20 for a switch and saved myself $200.
Exterior grade sump pump Jeeper1970 Plumbing 11 12-02-2016 10:17 AM
Not your normal sump pump question..(electrical) windowguy Electrical 13 10-03-2011 01:17 PM
Sump pump large draw of power BlueBSH Electrical 1 03-16-2011 10:51 AM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
