Replaceable Pipe Under Concrete - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-15-2009, 05:21 PM   #1
Replaceable pipe under concrete
we are going to have a concrete slab poured. Im wanting to run a pipe from the hot water heater in the utility room going under the slab (across the hall way) to a bathroom wall about 4 to 5 feet away. I really dont want to go up and through the attic. However I want to be able to replace the pipes if they was to ever leak. I can use up to a 4" secondary pipe size as this will be the size of my vent line anyway in that wall. Is there some kind of strong dependable lines I can run through a secondary pipe for a short run under slab like Im wanting and still be able to replace them later if needed because of a leak ?
Mudball is offline   Reply With Quote
Old 08-15-2009, 08:42 PM   #2
Since Ive posted this question Ive received a possible solution. Something that might work would be two sweep 90's. I think I could slide two 1/2" pipes through a 4" piece. I will have to go to a supply house and try to experiment.
Old 08-16-2009, 06:38 PM   #3
Master Plumber Lon
Send a message via Yahoo to lonsplumbing
sleeving
Use 2 - 45's elbows it will be easier.
lonsplumbing is offline   Reply With Quote
Old 08-17-2009, 08:00 PM   #4
That sounds like a great idea.
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 08:21 AM
Underground orangeburgh pipe leading to storm sewer is blocked somewhere flashme18 Plumbing 10 07-21-2008 11:48 PM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
drain pipe depth under concrete amakarevic Plumbing 4 07-27-2007 07:35 PM
