Replace A Washing Machine Shutoff Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-02-2011, 01:57 PM   #1
Replace a washing machine shutoff valve
Do you have to solder the connector, or does it screw on the water line
Ralphknapp is offline   Reply With Quote
Old 09-02-2011, 03:04 PM   #2
fabrk8r
fabrk8r's Avatar
Both types of shut off valves are available. Whether you use a threaded valve or a solder type will depend on how the existing valve is configured.
Do you currently have a single lever valve or two separate valves?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Replace toilet water shutoff valve abastin Plumbing 14 02-14-2011 03:41 PM
washing machine hookup problem poppito Plumbing 5 03-11-2010 02:17 PM
Washing Machine Drain Pipe tjeieio Plumbing 2 02-25-2010 05:19 PM
Plumbing a Washing Machine Drain MikeWood Plumbing 2 01-21-2010 07:10 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
