Old 11-15-2009, 09:41 AM   #1
replace uneven toilet flange?
Just found out the washroom floor and flange are uneven.. The floor end far from the door is 1 5/8'' higher. I am thinking of using cement to even out the floor, then what should I do with the flange? It is uneven and will be much lower than the floor after I apply the concrete and lay the tiles.
Any feedback would be very welcome!! Thanks all!!!
Sam
replace uneven toilet flange?-pict0002.jpg   replace uneven toilet flange?-pict0005.jpg   replace uneven toilet flange?-pict0006.jpg
Samw09 is offline   Reply With Quote
Old 11-15-2009, 09:41 PM   #2
It seems like the floor is concrete. It does not say, but it must be concrete.
If it was plywood floor, it would have been a lot easier. But, concrete floors
are a lot more difficult. The floor is uneven; the flange is not unveven.
Once you level the floor, then it is easy to install the flange on top of the
concrete. But, it is a lot of work to level the floor. Good Luck.
gabriel246 is offline   Reply With Quote
Toilet Flange Questions LeviDIY Plumbing 13 06-04-2009 02:22 PM
closet flange trouble for antique toilet diyb Plumbing 4 05-20-2009 09:07 PM
Toilet closet flange kensington Plumbing 5 04-27-2008 09:19 AM
Toilet Flange and Flooring brneilly Remodeling 4 04-20-2008 12:37 PM
Replace a PVC Toilet Flange bcdad Plumbing 4 12-06-2007 04:46 PM
