Replace Toilet Water Shut Off Valve Knob - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-25-2012, 08:02 PM   #1
Replace Toilet water shut off valve knob
The knob on the water shut valve for my toilet broke in half. I bought a new knob. Do you have to shut the water main off to replace it? It look like I just unscrew the old one & rescrew in the new knob.
ifixit is offline   Reply With Quote
Old 11-25-2012, 08:06 PM   #2
Yup, just unscrew & replace. No need to shut the water off.
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
ifixit (11-25-2012)
Old 11-25-2012, 08:23 PM   #3
DIY staff
Rewards Points: 7,174
I do hope you were just talking about the handle and not the entire shut off valve.
Old 11-25-2012, 08:51 PM   #4
Rewards Points: 582
yep thats what i was thinking mike..hope its just the handle and not stem...
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (11-26-2012)
Old 11-26-2012, 05:26 AM   #5
DIY staff
Perhaps op will come back with 'removing wet drywall' question next.
Old 11-26-2012, 09:01 AM   #6
Considering we do not know exactly what the problem is that you are dealing with, it would be best if you turned the water off to the supply to the toilet. If for some reason you were to torque on the shutoff valve, slip and fall against it, or hit it with a tool, it is always safe to shut the water off. This 2 minute adjustment could save you from a very pricey fix if the water were to leak. Always be safe, not sorry.
jnc401 is offline   Reply With Quote
toilet tank fills even after wall valve shut off msmitymite Plumbing 9 09-11-2016 09:21 AM
water loss shut off valve ashley123 Plumbing 1 08-21-2011 08:35 AM
Main water valve in condo shut off, but neighbors can still hear water running through pipes. cookiebird87 Plumbing 1 12-01-2010 04:43 PM
I still hear water running when I shut off the main water shut off valve jnut Plumbing 6 07-15-2009 07:46 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
