Replace Toilet Fill Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-24-2009, 10:25 AM   #1
replace toilet fill valve
I replaced the fill valve in my toilet. When I flush and the water begins to fill the tank through the valve a loud knocking sound occurs which appears to be stemming from the water source piping leading to the toilet. Do you know what this can be?
jmauro1964 is offline   Reply With Quote
Old 09-24-2009, 11:35 AM   #2
is the valve in the full-open position?
djrussell is offline   Reply With Quote
Old 09-24-2009, 11:44 AM   #3
No it does appear that I can eliminate the banging sound and vibration by opening the valve more but then it is noisy while filling up and fills quickly as well. Should these water be opened to the full position?
Old 09-24-2009, 05:37 PM   #4
you might have to deal with the noise. the banging is probably the water getting choked inside the valve. it's just a 1/4-turn right? let 'er rip.
Old 09-25-2009, 08:23 AM   #5
I just want to confirm when we are talking about the valve being in the full open position I am talking about the water source. SO I opened the water source to the full position. The banging does not occur but the filling of the tank is a little loud but fills quickly.
Old 09-25-2009, 12:53 PM   #6
yeah, the shutoff valve on the wall/floor.
Old 09-25-2009, 12:59 PM   #7
Yes on the wall. The same valve I used to turn off the water when I replaced the fill valve. Thanks for your input.
Old 09-26-2009, 12:04 AM   #8
If it is coming from the water line before the valve it sounds like water hammer. you can purchase a water hammer valve that is easily installed. Or a copper line is loose and hitting something under the house or if its on a second floor under the floor
Daniel048225 is offline   Reply With Quote
Toilet Valve eddie3449 Plumbing 6 03-05-2009 02:41 AM
please help me remove toilet valve made of plastic wfang Plumbing 3 01-02-2009 08:55 PM
Is it time to replace the toilet? Deahmx Plumbing 8 08-12-2008 01:11 PM
Toilet valve replacement? steve771 Plumbing 18 07-10-2007 10:50 AM
