Replace Sump Pump Check Valve Its Got A Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-15-2011, 08:05 PM   #1
Replace sump pump check valve its got a leak
My check valve started spraying right from the seam in the middle when the pump kicks on. I ordered the same one a jackel model D J 545.
It looks simple enough to replace myself. Do I have anything to worry about or just loosen the clamps and slip the new one on?
Right now i have it duct taped with a rag around it to keep it from spraying all over the place.
detyianni is offline   Reply With Quote
Old 05-15-2011, 08:27 PM   #2
It is simple enough, just make sure you recognize the direction of flow that will be marked on the side of the check valve, it should be pointed upward.
Dougtheplumber is offline   Reply With Quote
Old 05-15-2011, 09:06 PM   #3
Thanks I appreciate the reply. With this crazy rain I don't want to risk messing it up.
Old 05-16-2011, 05:11 AM   #4
Chicago, IL
Michael Thomas's Avatar
If the pump is in a location where you can hear the check valve closing when the pump turns off, and you find the sound annoying, this is a good time to install a "quiet" valve, (ex:, the Campbel B-0823 series).
(For the record: I have no business relationship with any manufacturer of any brand of check valve.)
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 05-16-2011, 05:38 PM   #5
WDR
valve
Remember that if the leak is on the pump side you could get a shower when you remove the valve as all of the water in the pipe will rush out the end.
WDR is offline   Reply With Quote
Well Water, Fluctuating Water Pressure, and the Roller Coaster Pressure Gauge huuuss Plumbing 24 12-11-2011 09:03 PM
Delta scald guard shower valve leak pdamania Plumbing 1 03-08-2011 05:45 PM
Sump pump float height dac122 Plumbing 8 12-08-2010 08:47 AM
Question about sump pumps and check valves lennyseleven Plumbing 3 11-08-2007 10:33 AM
Sump pump re-hab mpking Plumbing 1 11-07-2007 11:29 PM
