Replace Stub-out For Bathroom Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-18-2013, 08:10 PM   #1
Replace stub-out for bathroom sink
How I replace the stub-out (I think that's what it's called) for a bathroom sink? It would work as-is, but I want to put in a pedestal for this remodel, so I want all the plumbing to look pretty, and it sticks out too far to get a reasonably sized decorative flange over it. I'll attach a photo of what it looks like right now. Does it just unscrew?
I guess I could add a picture to show the whole thing. I just finished replacing the old valves.
jason42 is offline   Reply With Quote
Old 04-18-2013, 08:15 PM   #2
Rewards Points: 14,290
Can not tell much from that picture, the pipes to nasty to see much.
The green means it could be copper or brass, or bronze.
That back walls so messed up it's to need to be redone anyway so open it up and see if you can see threads.
Old 04-18-2013, 08:22 PM   #3
It's the bit that has that green color that needs to be replaced. It looks like it maybe threads into the piece behind it. This house is 50 years old if that's any clue. I'm not sure why it sticks out so far but the "drywall by hammer" work there makes me think it was changed by DIYer sometime in the past. It used to be all hidden inside a cabinet.
EDIT: I took a wire brush to it, and that piece is copper. Does that mean it's likely soldered in there?
EDIT2: At least it's copper colored. I guess that could be brass? Sorry for the dumb questions, but I'm just learning how to do this stuff.
Old 04-18-2013, 08:56 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 902
cut the copper back and solder one of these copper trap adapters
http://www.pexsupply.com/Cello-WDFSJ...er-FTG-x-Compr
Old 04-18-2013, 09:07 PM   #5
Thanks, I'll take a look at that for the weekend. One issue is it looks like someone put some vice grips or something on it sometime in the last half century and it's a bit bent out of round. I still need to learn how to solder things on as I've only used the torch to remove the old valves. At least with the drain stuff, a bad solder won't flood the house.
Old 07-01-2013, 06:44 PM   #6
Thanks for the help everyone. The funny thing is when I was all done, you can't even see the plumbing I worked to make look nice.
The Following User Says Thank You to jason42 For This Useful Post:
TheEplumber (07-01-2013)
old cement utility sink helpmyhusband Plumbing 31 09-26-2016 07:53 AM
Would you replace these valves under the sink? (picture) addfsd Plumbing 27 03-03-2013 10:57 AM
replace utility sink drain jimmyfloyd Plumbing 3 12-27-2012 08:38 AM
Replace old kitchen sink drain or leave it? CoconutPete Plumbing 23 02-02-2012 01:20 PM
Pedestal sink drain replace sasman Plumbing 1 01-28-2009 06:08 AM
