Replace Sink Shutoff Valves? Compression? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-16-2011, 05:27 PM   #1
Rewards Points: 590
Replace sink shutoff valves? Compression?
I need to replace the two brass colored corroded shutoff valves. Assuming these are compression fitted on to CPVC, what is the replacement procedure?
Unwrench the valve, cut the compression ring off and then install the new one?
Can I use the brass compression ring that comes with the valve to install the new one? I think it's standard CPVC pipe, 3/4" OD?
Thanks.....
noone is offline   Reply With Quote
Old 11-16-2011, 08:29 PM   #2
Rewards Points: 590
I guess what I really want to know is-
1. Can I use the brass compression ring on the 1/2 in CPVC?
2. Can I refit the new valve over the same piece of CPVC the previous valve was on or do I have to seat it on a fresh piece, therefore requiring me to cut the length of the pipe sticking out of the wall. I'm not sure this is even possible because the current valves sit almost flush to the drywall.
Thanks for the help.
Old 11-17-2011, 07:53 AM   #3
Rewards Points: 590
bump??
Old 11-17-2011, 08:21 AM   #4
DIY staff
Rewards Points: 7,174
Sorry this has sat for a while----
Use the old nut and washer if you can----
Do not use the brass ring if you must change the nut---you need a tapered nylon ring for that--
Old 11-17-2011, 09:13 AM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
On old CPVC I would much rather see a glued on male adapter threaded into a valve, rather than compression forces on old pipe that may be brittle and prone to cracking.
Journeyman Plumber
Old 11-17-2011, 09:31 AM   #6
Rewards Points: 590
Good tip, but how does this 'look'?
These are going to be exposed valves.
How do you trim this out so it looks good?
Old 11-17-2011, 09:35 AM   #7
Rewards Points: 590
when you thread the new valve into the male adapter, should you use pvc tape or pipe dope on the threads?
Old 11-17-2011, 02:31 PM   #8
Rewards Points: 590
another bump.
"when you thread the new valve into the male adapter, should you use pvc tape or pipe dope on the threads? "
I really need to know how to do this right and could use some advice from some plumbing professionals out here....
I don't want to come home to a flooded house.
Thanks!
Old 11-17-2011, 06:14 PM   #9
DIY staff
If you use a compression valve --no dope or tape---those threads don't hold water--only pulls the nut and valve together --the nylon ring does the sealing.--Mike---
noone (11-17-2011)
Old 11-17-2011, 06:46 PM   #10
raylo32's Avatar
Rewards Points: 1,286
Mike, I think this last question was asking about threading a FIP valve onto a MIP adapter that had been glued onto the pipe stub. If you do this use either teflon tape or dope. I prefer the tape myself. Also, if you get one of those "micro leaks" where you have a drop every half hour or so from the threads don't worry too much. It'll usually stop in a few days as minerals get deposited.
raylo32 is offline   Reply With Quote
The Following 2 Users Say Thank You to raylo32 For This Useful Post:
noone (11-17-2011), oh'mike (11-17-2011)
Replace toilet water shutoff valve abastin Plumbing 14 02-14-2011 03:41 PM
Venting a sink pump WillK Plumbing 2 12-26-2010 01:21 PM
Suspended/Floating sink installation? How? techprincesse Building & Construction 3 11-21-2010 03:05 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
Bathroom Sink Shutoff Valve, Supply Lines, Removing CathrynH Plumbing 9 01-10-2008 12:28 AM
