Old 01-15-2010, 06:13 PM   #1
Replace outdoor cast soil stack with PVC/ABS
I am trying to find out if it is 1. Legal 2. Functional to replace my cast iron waste stack that is outside with a plastic one. Do I need to worry about the NE weather damaging it? I live in a three story rowhome in Philadelphia that I am renovating. I have decided that while I am renovating I should replace the pluming that goes to the stack and the stack itself to head off any problems.
Thanks!
crazychef55 is offline   Reply With Quote
Old 01-15-2010, 08:12 PM   #2
A "Handy Husband"
rjniles's Avatar
Unless the cast iron stack has a problem, why would you replace it. It looks much more historically accurate than a PVC stack for a old row house. If you need to replace with PVC, I would find a way to get it inside the building or build an exterior chase.
Coastal South Carolina
rjniles is offline   Reply With Quote
Tags
drain, sewer, stack
Help with soil stack leak tmbrink Plumbing 10 03-08-2009 11:44 PM
Corrosion problem in vent stack. sgbotsford HVAC 2 12-01-2007 03:47 PM
Soil stack "cover"? DIYGmaLynn Plumbing 3 09-04-2006 01:23 AM
DWV Stack Question dcgray2 Plumbing 9 07-14-2006 01:56 PM
