-   -   Replace old kitchen sink drain or leave it? (http://www.diychatroom.com/f7/replace-old-kitchen-sink-drain-leave-130498/)
CoconutPete 01-18-2012 12:49 PM
We are redoing the kitchen in our 1930 cape.
The drain under the kitchen sink is original. It goes into the wall/floor at a 45degree angle where it is cemented in place.
Downstairs in the basement under the kitchen: The lead pipe comes down, curves to the right almost 90 degrees, runs about 2' to the right and then curves back down to vertical into the cast iron stack.
I don't have drainage problems with it, I'm just considering this since we are remodeling and since it's 82 yrs old and made of what appears to be lead.
I guess the alternative would be to just cut it - leave the piece in the wall and then go straight through the floor with a new pvc one and curve that into the drain stack?
joecaption 01-18-2012 12:58 PM
#1 we need pictures, can not see it from here.
That drain if redone needs to go through the wall not the floor.
While your in there if there's old steel supply lines replace all of it. There going to plug up and leak at some point.
CoconutPete 01-18-2012 01:03 PM
Will post a pic when I get home. Luckily, supply lines have been replaced at some point and are copper w/ nice new shutoffs.
TarheelTerp 01-18-2012 01:13 PM
When you have full access to something...
or even if you have pretty good access to it...
do it all and be done.
Javiles 01-18-2012 05:33 PM
You can do it now or later, but it will need to be replaced, how long 3 months? a year.
ben's plumbing 01-18-2012 06:37 PM
yes yes yes its open REPLACE IT :yes:
CoconutPete 01-18-2012 08:40 PM
1 Attachment(s)
Under the sink
1 Attachment(s)
Basement view
ben's plumbing 01-18-2012 08:42 PM
Originally Posted by CoconutPete (Post 827327)
Basement view
replace it ..replace it replace it....ben
CoconutPete 01-19-2012 07:03 AM
From the cast iron and up?
That looks like a crapload of solder, does that sound right?
oh'mike 01-19-2012 07:13 AM
That curved piece is soft lead--you should be able to remove that from the cast iron hub without to much work
There will be oakum packing around that pipe and more lead poured in to hold the lead pipe.
Going up through the floor would be easy and acceptable-- With the age of the house--there may not be a vent ---You will know when you open the wall.
A proper vent is best--up to the roof---but if that's not practical--an AAV will work if allowed in your area.
CoconutPete 01-19-2012 08:08 AM
I LOVE THIS PLACE! :thumbup:
I'm almost certain there is no vent up there because:
The sink is in front of a window.
Also: The cast iron pipe you see in the picture runs down toward the floor where a bunch of things meet: Washing machine drain, another drain that goes up to the bathroom above and a big vent pipe.
It's going to be next to impossible to get a dedicated vent all the way up for this drain. I'd have to tear out the bathroom wall and space above the bathroom is even tigher because it's in the shed dormer.
1 vent for bathroom/kitchen and washing machine...... is that enough by modern standards?
Think my next phone call this morning will be to the town to see how they feel about an aav.
TarheelTerp 01-19-2012 08:53 AM
How about learning which code & adoptions your town uses...
and what THAT says about AAV's before calling them?
Try to avoid asking inspectors too open ended a question whenever you can.
a quick google *implies* you're on the 2003 IPC
http://www.archive.org/stream/gov.ct...mbing_djvu.txt
CoconutPete 01-19-2012 09:08 AM
It's not that I don't want to, in fact I have a PDF of it saved, and yes my town does provide a link to it on their website also.
It's the fact that whenever I try to look something up I usually feel dumber after reading it than before I started. I feel like politicians wrote it sometimes and their main goal was to write it in such a fashion that us regular people can't understand it.
I did find this though, which seems promising:
917o4 Locatlom. The air admittance valve shall be located a minimum of 4 inches (102 mm) above the horizontal branch drain or fixture drain being vented. The air admittance valve shall be located within the maximum developed length permit- ted for the vent. The air admittance valve shall be installed a minimum of 6 inches (152 mm) above insulation materials.
oh'mike 01-19-2012 09:41 AM
Sounds like you are good on the AAV---I'm a firm believer in replacing as much old pipe and electrial as possible while the room is torn up---
Looks you you think that way,too.
