Old 03-14-2012, 05:48 PM   #1
Replace My Whirlpool Water Heater with Which Brand?
About five years i bought a Whirlpool gas fired 40 gal water heater.
A couple years later it failed. Whirlpool sent me a replacement assembly that included the pilot light thermocoupler, therm safety switch, et. al.
I managed to successfully install it and the water heater worked. A couple of times it stopped working. I had to clean the air vents under the unit. (Is this a stupid design or what?)
Last week it stopped working again. I've called Whirlpool four time. It's still not working. They want be to buy a volt meter then unscrew a copper line and check for voltage.
At this point I 'm going to buy another water heater.
I'm looking for recommendation for good 40gal gas fired water heaters.
Thanks,
Hermes.
hermes is offline   Reply With Quote
Old 03-14-2012, 06:43 PM   #2
call me E
TheEplumber's Avatar
Whirlpool is just walking you through the normal diagnostic steps. Volt meters are part of troubleshooting.
But if you want a new heater I vote for rheem or bradford white
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (03-17-2012), hermes (03-14-2012)
Old 03-14-2012, 08:34 PM   #3
I think Rheem's have some of the same problems. Look like Bradford White for me if i can find it in my area. Or maybe tanksless if it's not too expensive.
http://www.plumbingzone.com/f2/ameri...efective-6009/
Old 03-14-2012, 09:29 PM   #4
Lochinvar is another thought well of, I think.
Old 03-14-2012, 09:54 PM   #5
GC/Master Plumber/Mech
Nothing wrong with Rheem. I have install a heck of a lot of them with no problems.
On the other hand Whirlpool, State and Reliance water heater SUCK problem after problem.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 03-17-2012, 07:00 PM   #6
OK. Where is the air intake on the Rheem?
Turns out the problem with my Whirlpool a bad thermocoupler. Replaced it and all is well ,, for now. . . . ( I had previously replaced the manifold door assembly)
Stopped by Lowes to pick up replacement and was stunned to see they're still stock/sell the same defective model with the upgraded door manifold assembly.
Unbelievable.
I'll add RHeem to the short list. What do you think of GE 40gallon gas fired tanks.
I saw one at Home Depot it looked pretty good. air intake on the side of the tank not the bottom, brass drain valve & self cleaning whatever that means.
Old 03-17-2012, 10:42 PM   #7
Thanks,
Hermes.
bradford white all the way
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 10:47 AM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
