Replace Kitchen Sink Cut-off Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-15-2012, 05:50 AM   #1
I replaced the cut-off valve on the water line, but I am unable to remove the bolt on the copper pipe. There is a little bulge in the pipe that prevents me from removing the bolt. Water is leaking like crazy. How can I remove this bolt and put a new one on?
MBVILLA is offline   Reply With Quote
Old 08-15-2012, 07:46 AM   #2
Rewards Points: 6,652
Post pictures.
Old 08-15-2012, 10:34 AM   #3
Rewards Points: 13,712
What bolt? There are no bolts used in plumbing.
Do you mean compression nut?
Old 08-15-2012, 07:16 PM   #4
Rewards Points: 79
Sounds like you have copper faucet supply lines and mean the ferrule. No way to get it off but you can cut the supply line to get the old nut off. Then use new copper supply and ferrule or just run a braided supply from the shut off.
eclark is offline   Reply With Quote
Old 08-15-2012, 07:25 PM   #5
Rewards Points: 2,516
is this ferrule what you are referring to as a nut?
Replace Kitchen Sink Cut-off Valve-fh01nov_leshva_03.jpg   Replace Kitchen Sink Cut-off Valve-fh06oct_leajoi_06.jpg
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
eclark (08-15-2012)
Old 08-15-2012, 08:40 PM   #6
Nice picture Hammer lane , it shows someone using teflon tape on compression fittings, and dope where the ferral seals. Not a great thing to be showing DIY's.
Wrong way to be doing it.
Old 08-15-2012, 08:46 PM   #7
DIY staff
Rewards Points: 7,174
Yep---no tape on a compression fitting--the threads are used to pull the ferrule and the bottom lip of the valve together---not holding water--so no tape.
TFE paste is not needed either---
Old 08-16-2012, 06:08 AM   #8
A drop of oil on the threads is OK. I agree no paste on the ferrule. Just grabbed some photos to make sure the poster was referring to what is commonly called a ferrule.
oh'mike (08-17-2012)
General Help with replacing shut off valve under kitchen sink- Pics included amodoko Plumbing 4 04-02-2012 04:34 PM
Resetting Undermount Kitchen Sink Voss Plumbing 0 02-24-2012 12:47 PM
temporary set up in utility room for kitchen renovation (sink; dishwasher) ilyaz Plumbing 3 01-25-2010 06:07 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 08:43 AM
