-   -   Replace Iron with PVC on DWV cross (http://www.diychatroom.com/f7/replace-iron-pvc-dwv-cross-9158/)
froddan 06-14-2007 06:02 PM
Hi!
I am in the process of replacing a single sink in a bathroom with two sinks located about 40 inches apart.
The current drain/vent pipe is steel in good shape, but I need to replace at least the part where the drain and vent connects to the P-pipe with a cross that goes both ways for the sinks.
I was planning on replacing this part with PVC to make it easier.
The pipe is 1.5 inches, will that be enough for the two sinks to come together at?
Thank you!
Fred
Ron The Plumber 06-15-2007 07:56 AM
Yes 1-1/2" pipe will work.
froddan 06-15-2007 04:05 PM
Thanks Ron!
Thank you Ron!
I'm happy that you say it will work with 1.5 inches, I read somewhere that it required 2 inches for double sinks, but this will make things much easier.
Now I just need to make sure I can get the fitting off from the Steel pipe, I have a feeling it might be really tight.
