-   -   replace hose faucet anti siphon / AVB (http://www.diychatroom.com/f7/replace-hose-faucet-anti-siphon-avb-172953/)
DIYGST 02-25-2013 11:38 AM
1 Attachment(s)
I cannot use a hose with this faucet, the water just comes out on the tiny holes which it is not supposed to. I know what this device does but I don't know how to remove it. It appears a set screw is broken to be tamperproof, but 20 years later, it's at end of life.
Would the threads on the hose bib be a standard garden hose thread (MHT) or something inside? Please let me know how to replace short of removing the whole faucet.
joecaption 02-25-2013 11:58 AM
It just unscrews from the faucet. There is no locking screw holding it on.
TheEplumber 02-25-2013 12:08 PM
199 Attachment(s)
You need to drill out the tamper resistant screws. Then it will unscrew using adjustable pliers.
It has female hose threads and the replacement part is about 10 bucks at HD/Lowes.
If you use a spray attachment on your hose the VB will spit water-that's as designed
DIYGST 02-25-2013 01:20 PM
I am going to try to drill it out without damage. how big of a drill bit do I use? A little bigger than the screw itself?
I have also heard of the inside thread is not a garden hose thread but a fine thread? I hope that is not true ..
TarheelTerp 02-25-2013 01:46 PM
What's on the OTHER side of that wall?
I'd be inclined to change out the done it's duty faucet as well...
and by that make the rest of the job simpler.
DIYGST 02-25-2013 01:59 PM
inside is copper plumbing and galvinized 6" long nipple (guessing) coming out the stucco and the faucet is screwed on the nipple.
If I replace the faucet, what do you use to grab on the galv so I don't accidentally tweak something inside the wall that I cannot see.
I would rather not because the faucet isn't dripping, and replacing the AVB is something I can try first..
Hardway 02-25-2013 02:06 PM
“If you use a spray attachment on your hose the VB will spit water-that's as designed.”
That is not correct unless the VB is bad no matter what is on the end of the hose it will not activate it. Let’s say for some reason the hose is in a dirty swimming pool and water pressure is lost at the main. The Vacuum breaker will open prevent the dirty water from being sucked back into the fresh water supply!
Hardway 02-25-2013 02:08 PM
You would need someone to hold the pipe inside. By doing so, you may invoke the mushroom affect.
DIYGST 02-25-2013 02:11 PM
The galv nipple does have exposed about 2" out of the stucco easily.
What is mushroom effect?
Hardway 02-25-2013 02:13 PM
The mushroom affect, when you start out to do a 10 minute repair that turns into an all day job!:laughing:
Hardway 02-25-2013 02:15 PM
Then you may be able to hold the nipple with channel locks and replace the sill cock (faucet).
djlandkpl 02-25-2013 02:52 PM
Use a drill bit about the same size of the screw or a little smaller. There's not much to those set screws and it should come out easily. The thread is hose thread.
TheEplumber 02-25-2013 03:08 PM
199 Attachment(s)
I googled and discovered another method- cut across the VB body with a hacksaw- don't damage the bib threads, Then pry apart the cut slightly. This relieves the set screws from the threads and you can unscrew it.
TarheelTerp 02-25-2013 04:38 PM
...inside is copper plumbing and galvanized 6" long nipple
With TWO wrenches... one on the galv nipple and the other holding the fitting it is threaded into still... twist the nipple out of the fitting.
Spary it all with PB blaster and turn the water off in advance.
Now or later. Your choice.
Avoid the mushroom.
funfool 02-25-2013 05:00 PM
We have a lot of those old style hose bibs around town here, our plumber likes them because they are made well. Better then the Chinese junk you buy today.
He buys the stems and packing to repair them a dozen at a time and always have some on his truck.
I am interested in this thread because I also have the same problem with a vacuum breaker on a frost free hose bib, have the mushroom affect fixing it. Yours just has the regular hose threads, if you remove it, is your choice if you want to put another back on.
It is something that someone else added.
All the ones I looked at today that will not work for me because I do have different threads. None like yours had set screws and should just unscrew.
But some good ideas here to remove it if they are set screws.
Wanted to add, some I looked at today seemed to have some sort of a thumb screw on the side that may be fore releasing pressure or some other purpose.
But was not a set screw.
