Replace Hose Bibs - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-01-2009, 07:06 PM   #1
Replace Hose bibs
The hose bibs on my house are old and the handle has broken off of the one on the front, it is also out from the brick too far. The hose bib on the back has a very slow leak, just wasting water. How easy is it to replace them. On crawl with copper lines.
Toolmaster is offline   Reply With Quote
Old 04-01-2009, 08:19 PM   #2
Safe, Most of the Time!!
brokenknee's Avatar
It is just basic plumbing, shut off water, cut, pull out old, sweat in new. How hard depends on how much room you have to work with.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 04-01-2009, 10:22 PM   #3
never worked with copper, what all do I need to do some sweating
Old 04-02-2009, 03:19 AM   #4
brokenknee's Avatar
Here is a good thread to read; How To Solder Copper Pipes
I am not sure if I would start my first project working in a crawl space though. You may want to repair what you have until you have developed your soldering skills. You should be able to purchase a new handle and then replace the washer and seat on the bib that is leaking.
Old 04-02-2009, 07:28 AM   #5
you should look in to a frost free hose bib
metx is offline   Reply With Quote
Repairing Electric Central Vacuum Hose jogr Appliances 6 11-11-2008 12:59 PM
Replacing a hose from water assembly? Ulf Berglund Appliances 3 08-16-2008 07:40 PM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 09:40 AM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 12:27 AM
Washing machine drain hose morrisp Plumbing 3 09-01-2006 07:24 PM
