-   -   Replace Drain Field? (http://www.diychatroom.com/f7/replace-drain-field-20145/)
namderd 04-20-2008 07:56 PM
The drain field on my septic system has failed. Can I just rent a compact backhoe, dig it up, replace the pipe, and cover with gravel?
Is this legal for a DIY project?
USP45 04-20-2008 08:59 PM
No you can not just dig it up and replace the pipe. The reason is the ground is what absorbs the waste water. When a drainfield goes sour its because the ground has become completely saturated and simply will not take any more water. Also as a DYI most all counties want someone who is licensed in this area to preform the work as there are a lot of things to take into consideration. lay of the land, trees, city or well water, property lines and more.
