Replace Boiler Coil With Hybrid Electric Hot Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-20-2013, 09:59 PM   #1
Replace Boiler coil with hybrid electric hot water heater
I have a boiler with a coil for DHW. I would like to install an electric hot water heater in place of the coil due to inconsistent hot water with the coil and costly to run during the summer. My question is what do I do with the coil in the boiler? I am guessing I can blow all of the water out of the coil and cap the inlet and outlet just in case the boiler ever leaks into the coil. Is this the correct way to deal with the coil? I would rather not use the boiler for DHW at all, since when I replace the boiler in a few years, I will not have a coil included in its replacement.
vansykes is offline   Reply With Quote
Old 04-20-2013, 11:50 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 650
Ayuh,.... Just disconnect it, drain it, 'n forgetabout it....
Nothin''s gonna happen to it...
Bondo is online now   Reply With Quote
Need help fast please re hydronic boiler water supply and backflow DanDaMan Plumbing 21 12-22-2010 08:01 PM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 03:26 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
Electric Water Heater Problem mw2727 Plumbing 4 08-21-2008 02:51 PM
Electric tankless hot water heater former33t Plumbing 2 02-28-2008 12:40 PM
