Replace Basement Shower Drain In Foundation Slab - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-20-2013, 12:05 PM   #1
Replace basement shower drain in foundation slab
I'm remodeling a basement shower, and want to replace the drain. Unfortunately, its set into the concrete foundation slab. I'm not sure what my options are - I could leave it there, but I'd rather not.
thanks!
Paul_in_VT is offline   Reply With Quote
Old 01-20-2013, 12:19 PM   #2
Depends. What system are you going with to waterproof everything? Fiberglass shower base or custom/tile finish?
BC Plumber is offline   Reply With Quote
Old 01-20-2013, 05:54 PM   #3
I did not think fiberglass base was an option because of the irregular position of the drain in the basin, so either tile or using the existing concrete floor (either polishing the concrete or epoxy paint) were the options I thought were in play.
Paul
Old 01-20-2013, 06:20 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
Demo enough concrete to move the trap and drain. Rent an electric jack hammer.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Paul_in_VT (01-21-2013)
Old 01-21-2013, 01:47 PM   #5
"You can do anything"-Mom
brockmiera's Avatar
I just did mine this weekend with my compressor, air hammer, and chisel bit. It took a little longer than renting a jack hammer but since I already had the other stuff it was a lot cheaper. Make sure you ventilate the area well, wear protective goggles and ear plugs.
brockmiera is offline   Reply With Quote
Porcelain Install Job on Basement Slab, How to make Floor Drain Flush... Firehawk734 Flooring 13 11-17-2011 09:30 PM
Crack Between Basement Slab and Foundation cweb2ny Building & Construction 15 06-01-2011 04:59 AM
Sewage smell from shower drain, trap has water, vent was snaked and was clear clearasmud Plumbing 1 04-24-2011 06:28 AM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 11:54 AM
Installing stand-up shower in finished basement without existing drain notenoughtime Plumbing 3 05-16-2009 11:59 AM
