Replace 25 Yo Delta Shower Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-11-2013, 12:43 PM   #1
Rewards Points: 280
Replace 25 yo Delta shower valve?
Hey Guys
I have a 25 year old brass shower valve with no markings on it other than up. The trim ring says Delta on it.
This appears to be the type of valve that takes a replacement cartridge. It is brass and soldered into copper lines.
Does this really need to be replaced? What info would you need to make a judgement?
There are no shutoff valves to this shower. What are the slotted screw heads and each side for?
jjrbus is offline   Reply With Quote
Old 05-11-2013, 02:07 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,390
I am almost certain that is a Delta 600 series... you are right, it is old.
However, parts are easily available for it, even at the HD's and Lowes. It is not a cartridge.
The silver cap unscrews and it comes apart. Take the parts and match them at HD. There is a ball type end on a stem, and the O rings and a rubber type seal and that white plastic part (and a handy little wrench for turning that white plastic thing).
You can buy the entire set, or almost each part in a package... I'd get all new parts ....$15 or so.
By the way... you can also get aftermarket trim rings and handles $40 or so, to dress it up in chrome or brushed.
That valve body was a very popular builder model. It won't quit... you might have to steel wool it's inside for some water deposit... but it is the energiser bunny of shower valves.
Do note... it is not temp or pressure balanced, and no longer code.
MTN REMODEL LLC is offline   Reply With Quote
Old 05-11-2013, 02:11 PM   #3
Rewards Points: 14,010
Loosen the lock nut where those screws are and turn the screw in to shut off the water.
Old 05-11-2013, 03:29 PM   #4
Rewards Points: 582
we installed hundreds of these faucets over a 40 yr period still going strong as mentioned parts easy to get ..just center ball seats and springs little bit of faucet lube ..good for many more yrs...delta were 1 st because we last..ben sr
Old 05-11-2013, 03:33 PM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Here's a tip on those valves : If the retaining ring gets siezed up and you force it, those little copper tubes on the back will twist and break. Especially after years of use if the tubing is worn out......
Personally, i'd replace it to something with a solid brass body, BUT parts are readily available for it, and if it looks like it's in good shape, then by all means you CAN certainly leave it in the wall. The best thing to do is clean the threads up on that ring very well (as well as it's counterpart threads on the valve body), and lube them up with a good faucet grease so that it will come off someday down the road when you need it to.
Journeyman Plumber
Old 05-11-2013, 04:19 PM   #6
Originally Posted by jjrbus View Post
...There are no shutoff valves to this shower. What are the slotted screw heads and each side for?
These are your shut-offs.
VIPlumber is offline   Reply With Quote
Old 05-11-2013, 07:41 PM   #7
Rewards Points: 280
Thanks everybody!
I finally get the answer I am looking for This spruce up of the bath as usual has gotten a bit out of hand and I do not need another project.
The shut off's seem to function properly but as mentioned the knurled ring is locked tight. Must be some old plumbers trick to loosen it? Now all I need is an old plumber.
Thanks again JIm
Old 05-11-2013, 07:56 PM   #8
Doing it myself
Alan's Avatar
Thanks everybody!
Thanks again JIm
There is no real trick. Try loosening with the maximum amount of pressure you can put on it with some channel locks without twisting the entire assembly. Be very careful not to twist it too far. If it won't break loose you can try some penetrating oil or something like that..... if it's that bad though, I usually just replace them.
Journeyman Plumber
Old 05-12-2013, 01:05 PM   #9
Rewards Points: 2,040
If you replaced the bath tub / shower your local code official may make you replace the valve to a pressure balanced anti scald. I suggest you call them.
Ghostmaker is online now   Reply With Quote
Old 05-12-2013, 02:14 PM   #10
I agree with Alan...... but if it's really important to try and use the old Delta and penetrating solvents don't work... try cutting it off by sorta scoring it with a Dremel or fine hacksaw and sorta prying/peeling it off.
But... make sure that your supplier does carry that cap piece to replace it.
Not that you want to waste money, but might be simpler and faster to just put in a new valve.
Old 05-13-2013, 07:38 AM   #11
Rewards Points: 280
An over night soak with PB blaster and it came right off
Thanks for the input, always greatly appreciated. JIm
I was biting my tongue on my response and had to come back and edit. If you need an anti scald valve in your house your water is waaaay too hot. You should not be able to cook with your hot water!
Old 05-13-2013, 08:49 AM   #12
GREAT
Jim... I'm one of those of your school... that codes are sometimes over protective. Risk assesment is a subjective evaluation. I often think that if you have a "code commission", it is somewhat a self perpetual creating job. If you don't keep finding something to require, you are out of a job.
I will say that people do turn up their water heaters all the way up (to have a large supply for multiple showers) and in a low pressure home if toilets flush or the washing machine goes on, the shower could get a little hot.... that's the logic I think. I'm sure the valves cost a little more... but at least they work.... it's afci's that PMO.... at high cost and complications....
Best Peter
Old 05-13-2013, 11:28 AM   #13
Plumber
Yes the valve can be repaired, But I think it would be foolish not to replace while the wall is open.
You'll be kicking yourself if it has to be replaced later.
DidIDoThat is offline   Reply With Quote
Old 05-13-2013, 02:54 PM   #14
Rewards Points: 280
Easy access from the back! I'd kick myself harder if I had trouble with a new valve!
Thanks for the input. JIm
How to replace the trigger valve on a Bostich Nail Gun. brokenknee How To Guides 10 11-08-2013 12:25 PM
Goodman GMP-0503 - Can't decide to replace valve or board first mikefrommt HVAC 3 11-10-2012 03:00 PM
Price-phister Shower hot side two valve O-Ring replacement? Bozohelp Plumbing 11 06-14-2011 04:44 PM
Delta Jetted Shower - install problems . . . Eusibius2 Plumbing 7 11-12-2009 11:21 PM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 06:46 AM
