Replace A 10" Rough In Toilet With A 12" Rough In - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-15-2009, 04:42 PM   #1
Replace a 10" rough in toilet with a 12" rough in
I have a 150 year old house. The old (low tank) toilet uses about 6-7 gallons of water to flush and has a 10" rough in. I want to replace it with a Toto Dartmouth (which I have in my half bath downstairs and love it). Problem is that the Dartmouth has a 12" rough in.
Would it be too difficult to change the rough-in to accommodate the new toilet? Would it be expensive to have a plumber change the rough-in? I know I can get the Toto Carrolton with a 10" (Uni-fit). but not crazy about it. Also the Dartmouth sits higher and would rather move to the more standard size rough in if possible.
Any help would be appreciated.
Last edited by Opie46; 05-15-2009 at 04:45 PM. Reason: added my old toilet has a 10" rough-in
Opie46 is offline   Reply With Quote
Old 05-15-2009, 07:30 PM   #2
HVAC / Plumbing
try one of these toilet flange offset.. Note......... may not meet code in your area.. Not the best ..But, I have used them
kenmac is offline   Reply With Quote
Old 05-16-2009, 10:49 AM   #3
10" IS the standard rough-in. Most 12" rough toilets need to be special ordered. As kenmac stated, you could go with the offset flange adapter although it goes inside the current pipe so it does reduce the size of the opening. Depending on what material the drain line is (may be a lead bend) , it may be possible to add on to the existing pipe to make it 12" rough.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 05-16-2009, 11:27 AM   #4
Rewards Points: 150
Not a big fan of offset flanges but if you insist on using the toto dartmouth it might be the way to go unless you can move the flange out 2 inches without it being too much of a hassle.
al's sewer is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 11:04 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
toilet leak after replace new wax ring druffino Plumbing 4 07-17-2008 10:31 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
