Repipe Home On Slab Foundation - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-02-2012, 10:05 PM   #16
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Originally Posted by Javiles View Post
This is a little test for all the plumbers on this site check out the video and see how many things you can find wrong with that job.??? If you where a plumbing inspector.
First question at around 2:10 : Why would you go to all that trouble and leave any cast iron under the floor at all?
Journeyman Plumber
Old 05-02-2012, 10:10 PM   #17
Doing it myself
Alan's Avatar
I can't watch the rest.
It's unfathomable how you can expect to tunnel under a slab like that and still retain stability. How the heck are they going to get the dirt back in there, and get it to the compaction level that it needs to be? How are they going to keep the uncompacted dirt from turning into a river of mud when a flash flood hits the area?
Those aren't even plumbing questions lololol
Journeyman Plumber
Old 05-03-2012, 12:19 AM   #18
Homerepairguy's Avatar
Rewards Points: 998
Here it is
My prediction is that over time, rain water will saturate the non compacted filled in tunnels causing the vertical walls of the tunnels to slowly cave in on the non compacted soil. This will result is large areas of poor support under the slab causing the slab to crack over the tunnels and sag down. This in turn will result in doors that won't close and other structural problems that are a much bigger headache for the home owner than the cast iron pipes ever were.
" But there will be nice, new PVC pipes under there (with some cast iron that wasn't replaced)."
Glad there wasn't a cave in during the tunnel digging and nobody was killed.
HRG
Homerepairguy is offline   Reply With Quote
Old 05-03-2012, 04:39 AM   #19
Ravenworks's Avatar
Okay here is an attempt to save face so you guys don't think I fell off of my nut.
I should have made my other post more clearer,I was referring to how they hung the piping from the slab,then I got to thinking,that wasn't a good idea either.
Because they further weakened the slab above.
As for the safety of the trench there is NO-WAY I would have done that without shoring,as for the back fill there are ways around that,but it only adds to the cost of the job.
But labour is cheap in Texas if your close to the boarder.
By the time the plumber gets done the guy could have built a new house,or broke because an OHSA compliance officer saw the flick.
No more posting for me when my logic has been compromised (beer),flame away I deserve it.
Ravenworks is offline   Reply With Quote
New foundation on old home blank8ball Building & Construction 8 06-14-2012 09:53 AM
Crack Between Basement Slab and Foundation cweb2ny Building & Construction 15 06-01-2011 04:59 AM
putting mobile home on an old house foundation rkr1991 Building & Construction 3 08-19-2010 09:20 AM
Adding foundation under a slab. bob grube Building & Construction 9 02-02-2010 11:08 AM
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 12:32 AM
