05-01-2012, 04:54 PM
#1
Repipe home on slab foundation
I was just wondering, is repiping a home on slab foundation much more expensive than one with crawl space or basement?
And either you do partial repipe, leaving alone the pipe portion under the slab, or you have to tear up parts of the foundation to do the whole repipe for the underground portions?
How much more is the typical cost, if so?
05-01-2012, 04:59 PM
#2
Depends your going to have to make some calls on this one.
Does it freeze in your area?
If not you may be able to run it through the attic.
05-01-2012, 09:12 PM
#3
Doing it myself
I guess my first question would be : " Do you want new water lines, new drain lines, or both?"
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
05-01-2012, 09:46 PM
#4
My area rarely freezes in Northern California, Bay Area.
Does that mean the old line is left intact in the home but disconnected so the meter connects to new piping?
05-01-2012, 09:47 PM
#5
I guess both? Was just asking out of curiosity in case I may want/need it.
Though I was primarily thinking of the supply line rather than the drains at the time of the post.
05-01-2012, 10:21 PM
#6
Doing it myself
The reason I ask is that if you're running drains, the concrete will be open for putting new water lines underneath as well.
I would say any time you have to work with concrete, you are looking at more money.
I'd much rather repipe from an attic, but that of course usually entails a lot more damage to sheetrock.
Journeyman Plumber
05-02-2012, 03:35 AM
#7
I wonder how often people (homeowners) do select repipe through attic? Is it common practice?
05-02-2012, 03:37 AM
#8
Also what if you have limited attic space? Use wall space and/or repipe with external pipe connections (exposed) outside house (for which you want to insulate, and hopefully not live in freezing climate).
Is repiping with exterior pipes an even rarer occurrence (even in non-freezing regions)?
05-02-2012, 05:38 AM
#9
I watched a you-tube video where they tunnelled under the house and hung the pipe with all-thread fastened to the floor above.
The whole time I was watching this all I could think about was how much $$$ the job was well done though.
05-02-2012, 07:49 AM
#10
Repiping design should be with the shortest possible path for the hot water lines to minimize wait times for hot water. Also, with a trunk and branch system, the hot water trunk lines will have to be 3/4" or 1" so round-about routing of trunk lines will make the wait times even longer plus a lot of water wasted.
Running lines outside of the house, even if it never freezes, would probably result in quite long hot water trunk lines with all of the disadvantages, not to mention possibly lowering the value of your home.
HRG
05-02-2012, 07:14 PM
#11
HRG
Understood, I was just wondering. But for the long pipe run for hot water issue, you can compensate with a water return line (dedicated return vs connect hot and cold lines together at fixture).
05-02-2012, 07:15 PM
#12
Ravenworks, do you have the link to the video? I'd like to see it for insight.
05-02-2012, 07:34 PM
#13
Here it is http://www.youtube.com/watch?v=vmIaqosVUHw
They have a very informative website,I was impressed by their job which is hard to do.
05-02-2012, 10:36 PM
#14
Master Plumber
This is a little test for all the plumbers on this site check out the video and see how many things you can find wrong with that job.??? If you where a plumbing inspector.
Experience is Knowing what to do next, Skill is knowing how to do it
05-02-2012, 11:01 PM
#15
call me E
I'm kind of claustrophobic, so I'd inspect it from the outside by yelling into the hole "make sure you vent everything"
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
