Repairing Toilet Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-23-2008, 11:03 AM   #1
repairing toilet flange
hi,
about 4 yrs ago, when we rented our house (we own it now), the landlord had a plumber fix a toilet, it was rocking. well its doing it again. i removed the toilet today, withour even removing the two mounting bolts! it has what looks to be a pvc flange and pipe. the slots in the flange are not broken, but pulled up from the rest of the flange. the only thing i can tell, is the bolts must of worked their way from the slots to the holes in the flange and popped out. would a good fix for this be to get one of those rings that fit over the old flange and screw into the floor/subfloor around the outside of the flange? also, i beleive that the subfloor is concrete. so should i mark and drill holes in the concrete, and insert anchors? or just drill and use small lag bots to secure the ring to the floor....bob
bobo60 is offline   Reply With Quote
Old 03-23-2008, 01:15 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Secure the bolts to the slots on the flange using extra nut and washer on each side, that will secure the bolts, now set the toilet. Thats how I do all my flange bolts, this way bolts wont slip out of the slots.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-23-2008, 01:28 PM   #3
Send a message via AIM to Marlin
If you go that route make sure you use a brass or stainless steel hardware otherwise it will seize making removal difficult and/or it will rot away completely. Are the slots in the flange deformed in any way?
Marlin is offline   Reply With Quote
Old 03-23-2008, 06:40 PM   #4
ron, marlin,
the slots dont seem to be deformed, just pulled up, like a small hump, i guess from being tightened too much. they are not broken. i will try to bolt the closet bolts to the flange, then set the toilet, and mount the toilet with nuts and washers from the top...bob
Old 03-23-2008, 06:45 PM   #5
Journeyman Plumber
If you can, run corrosion resistance screw into the sub floor near the slots on the flange, this will help in keeping the slots of the flange tight to the floor.
Old 03-23-2008, 08:33 PM   #6
You are correct. A raised area along the slots indicated over tightening or someone yanking on the bowl. Gently tap the area back down with a hammer and it should be fine.
As for anchoring into the slab use the plastic sleeves. You drill a hole, insert the sleeve then put the screw into that. I like the lead sleeves better but I don't think you can buy them anymore.
Old 03-23-2008, 08:43 PM   #7
Journeyman Plumber
Forget it was a slab floor, so Marlin have you going in the right direction.
Old 03-23-2008, 09:09 PM   #8
hi guys,
lots of great ideas, thanks! just thought of this. after i tap down the slotted holes. put a star washer under the head of the closet bolt. this way when i set the toilet, and tighten down the closet bolts, the star washer, should i hope grab into the pvc flange and not slide.
bob
Old 03-23-2008, 09:15 PM   #9
Journeyman Plumber
Should work, secure the bolts to the flange 1st, then set the toilet.
Old 03-23-2008, 09:24 PM   #10
Is the flange all PVC? Or does it have a metal ring around it? If it's all PVC forget my comment about hitting it with a hammer.
Old 03-23-2008, 09:24 PM   #11
hi,
ok. if i secure the bolts to the flange first, ill have to set the toilet over the flange, without the wax seal, and mark approximately where the bolts should mount to the flange?
bob
Old 03-23-2008, 09:28 PM   #12
Originally Posted by bobo60 View Post
hi,
bob
You can dry fit the bowl first to see where they go if you are more comfortable that way. Typically the bolts go as far out to the sides are you can get them. The holes in the bowl are much larger than the bolt so you have some play with it.
Old 03-23-2008, 09:32 PM   #13
Journeyman Plumber
Yes you can dry fit 1st, then adjust bolts if needed before you set with the wax.
Old 03-23-2008, 10:01 PM   #14
ok, gonna dry fit first, then mount the closet bolts with star washers under flange,and on top of flange to lock closet bolts in place, install wax seal on toillet, sit on toilet to press and seat wax seal, bolt it down. sounds like a plan...thanks again for your help!...bob
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Replace a PVC Toilet Flange bcdad Plumbing 4 12-06-2007 03:46 PM
Installing new toilet flange. helpless handyman Plumbing 7 11-16-2007 06:47 PM
Rusted toilet flange on PVC pipe wyoming777 Plumbing 15 11-09-2007 09:53 PM
Toilet Flange txbostont Plumbing 5 10-31-2007 11:01 AM
