Repairing Radiator Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-06-2009, 06:31 PM   #1
repairing radiator pipe
I have a radiator pipe that split open about one inch right where the blades start. Can I remove some blades, cut the pipe and replace with pipe only for that inch? How should I remove the blades?
Manute is offline   Reply With Quote
Old 02-06-2009, 06:43 PM   #2
Learning by Doing
Leah Frances's Avatar
How bad is it split? I've had luck repairing cracks on Iron Rad pipe with JB Weld.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 02-06-2009, 07:07 PM   #3
Thx for the reply. The split is not bad but it's copper. Can I remove the "blades?"
Old 02-06-2009, 09:39 PM   #4
yes, just twist and turn them off after you cut the pipe.
easy
II Weeks is offline   Reply With Quote
Tags
broken water pipe , leak , radiator
repairing air compressors drewhart Tools 5 11-28-2008 01:26 PM
need help on repairing rotted deck support ga1990 Building & Construction 6 11-07-2008 07:32 PM
Repairing Futon metal bars? mikehende General DIY Discussions 9 01-24-2008 09:04 AM
Repairing the wood for painting bofusmosby Painting 4 06-16-2007 11:55 PM
repairing plaster aliG Remodeling 3 01-02-2006 07:21 PM
