Repairing Pipe On Electric H/W Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-08-2012, 08:10 PM   #1
repairing pipe on electric H/W heater
I need to change out the pie on the hot water side of my heater, I have never just changed out a pipe. Do I need to shut off the power and drain some of the water?
how do I go about doing this? Do i need to shut off the cold water too?
Joe Tilghman is offline   Reply With Quote
Old 03-08-2012, 08:19 PM   #2
biggles's Avatar
shut the power and the cold water feed.drain off from the bottom petcock running a hose off it...open up all the hot water faucets above the heater in the house..this will vent the hot water line down into the top of the heater.lift the relief when the water is not coming out there your good to work the hot water pipe on top soldering and or threaded..
The Following User Says Thank You to biggles For This Useful Post:
Joe Tilghman (03-08-2012)
Old 03-08-2012, 08:23 PM   #3
Thanks bunches for yor reply
electric water heater shut off caryn keeper Plumbing 8 02-28-2012 06:39 PM
electric versus propane water heater Jeremy Hillary Boob, PhD Appliances 7 01-30-2012 05:23 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
Is my panel sufficient to add Electric water heater andy Electrical 16 04-21-2009 08:34 AM
Electric tankless hot water heater former33t Plumbing 2 02-28-2008 11:40 AM
