Repairing Old Galvanized Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-07-2008, 08:17 PM   #1
Rewards Points: 682
repairing old galvanized pipe?
I have an old galvanized water supply system, at least 40+ years old. The pipes are holding up fairly well for now.
I was thinking about replacing an angle valve, but I do not know what to do if the threads were completely corroded or the pipe was broken off. In such emergencies what can you do with old galvanized pipe?
I am not in a position to replace the whole system with new copper pipe.
darsunt is offline   Reply With Quote
Old 04-07-2008, 08:35 PM   #2
Send a message via AIM to Marlin
The only thing you really can do is try to unthread the nipple. You will have to hold back on the fitting it's threaded into and probably use a decent sized wrench. Heat will help, if it won't turn you might be able to cut it out. If you wreck the threads you need to try and take apart the next joint. Wreck those threads and you need to go back further and so on.
If you get the nipple out use another galvanized nipple. If you have to go back a ways use a die-electric fitting and convert to copper. Do not attach the copper right to the galvanized.
Marlin is offline   Reply With Quote
Old 04-08-2008, 01:39 AM   #3
Rewards Points: 682
Sounds like a pain in the *** but possibly doable.
It sounds like you can't cut new threads on corroded galvanized pipe.
Backing off OLD galvanizd pipe...& PVC to cast iron michael76 Plumbing 13 02-18-2009 12:18 AM
Repairing black poly pipe MelAuston Plumbing 4 10-31-2007 09:54 PM
Old Galvanized Waste pipe rodg2915 Plumbing 1 02-28-2007 03:39 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
