Repairing Leaky Outside Faucet... - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-02-2010, 07:55 PM   #1
Repairing leaky outside faucet...
Hi All,
I have a faucet outside for my yard that is leaking.. It is leaking when I turn the water on... Looks like it's leaking from the stem(See pics).
I would like to rebuild it if possible and fix it rather than replace because of the story below.
Story: second day in the house, I had the same issue in the garage. Eager to wash my car I decide to fix it.. I go to home depot and they say unscrew the old faucet, install the new one.. Problem is old one was welded... I had to replace copper tubing which wasn't bad but with the setup upstairs I don't have the room to do it...
Can someone help?
Thanks!!
Repairing leaky outside faucet...-img00344-20100802-2038.jpg   Repairing leaky outside faucet...-img00343-20100802-2038.jpg
jmejiaa is offline   Reply With Quote
Old 08-02-2010, 09:03 PM   #2
Rewards Points: 352
1st. That ground clamp is not hooked up to any wire. What happened to the wire?
2nd. Remove that big bonnet nut under the knob then unscrew the stem. If you can see what washers need to be replaced, then replace them. If it is perplexing go to a plumbing supply or plumbers shop show them your problem. The help at Homies or Blowes will strike out on this one.
plumberinlaw is offline   Reply With Quote
Old 08-02-2010, 09:08 PM   #3
Thanks.. I'm sure I could figure out.. Just wanted to make sure it was the right nut to remove(Which other could it be right?)
Also... I don't know what happened to the wire, it's a new house and I'm trying to correct some of the half assed jobs/maintanence items the other owners left.
Old 08-02-2010, 10:44 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 562
Need I mention to shut off the water supply valve first?
Old 08-02-2010, 10:45 PM   #5
Lol... I got that part covered :D
Old 08-03-2010, 09:23 AM   #6
Rewards Points: 352
your no fun.
Old 08-03-2010, 09:29 AM   #7
Hey guys, one more question. What does the ground wire do with the faucet, should I fix it?
Old 08-03-2010, 09:36 AM   #8
Rewards Points: 352
I am not that good with electricity but if there is a short circuit in the house that should take it to ground. Much better than your body taking it to ground. perhaps that question in the electrical forum could clear this up
Old 08-03-2010, 09:38 AM   #9
Thanks, I will post there and link to this thread for the pics+more info...
I'll try and get this leak fixed today
Old 08-03-2010, 08:23 PM   #10
Plumber
Rewards Points: 562
It could be telephone ground. I'm not a electrician but I thought they grounded through a 6' rod
Old 08-03-2010, 08:31 PM   #11
Owner
LateralConcepts's Avatar
Yep they do. I went to a job one time and found a 6' ground rod that had been hammered right through the guys sewer line. Camera showed shards of PVC, dirt, rock, and the ground rod. Think it was Ma Bell. Pretty sure he never recouped the money to fix it.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 08-03-2010, 09:13 PM   #12
Rewards Points: 1,578
Looks like the packing is gone. Back off the bonnet nut, wrap some packing (looks like black string) around stem, tighten up bonnet nut, and hopefully it will have stopped leaking. May be easier than finding a washer to fit the stem.
bob22 is offline   Reply With Quote
Old 08-07-2010, 09:08 AM   #13
So I got it off but home depot does not sell this washer. The guy told me I wouldn't be able to find it.... Take a look at the pic..
If possible I'd like to fix it as I would have to destroy the basement ceiling to get to the copper tubing to put in a new faucet....
Old 08-07-2010, 10:16 AM   #14
Rewards Points: 352
Hommies= Home Depot
Blowes= Lowes
Go to plumbing supply (The place most of the plumbers go)
Old 08-07-2010, 10:18 AM   #15
Hommies= Home Depot
Blowes= Lowes
I got it...
Followed this video and just used teflon!
leaky bathroom faucet; how do I change washer yummy mummy Plumbing 21 01-28-2012 01:13 PM
Leaky Delta bathtub faucet DOW Plumbing 4 01-04-2009 08:33 AM
Leaky Bathroom Faucet w No Markings cmcwittig Plumbing 6 12-23-2008 09:55 PM
Quick leaky faucet question JPfixit Plumbing 5 12-09-2008 11:21 AM
Help Repairing a 25 Year Old Delta Shower Faucet shapeshifter Plumbing 5 07-07-2008 08:24 PM
