Repairing Garden Hose Connection - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-10-2012, 11:50 AM   #1
Rewards Points: 16
I saw one of the garden hose was leaking where it attaches to the hose bibb. It has an adapter that attaches to the hose bibb.
The leaking was from those tiny holes in the adapter. The rubber washer (?) that sat against those holes were all cracked.
So, I thought I just buy a new hose and try to connect to the hose bibb. The male end of the hose bibb (the diameter is something like 1 and 1/8 or 1 and 3/16) is too wide for the standard hose that I bought at Home Depot.
I went back to the HD with the old hose and asked for the same adapter and they do not have such thing. I also just tried one of the larger plumbing supply store in LA, they do not have.
Could you provide some ideas how I can solve this?
Do I need something drastic like sawing off the pipe to remove the hose bibb and start all over with a new hose bibb.
Thank you.
Repairing Garden Hose Connection-bibb1.jpg   Repairing Garden Hose Connection-hose1.jpg   Repairing Garden Hose Connection-hose2.jpg
cl6120 is offline   Reply With Quote
Old 09-10-2012, 12:24 PM   #2
Rewards Points: 340
is the part connected to the hose bib part of the faucet itself or can it be removed (first picture)?
NitroNate is offline   Reply With Quote
Old 09-10-2012, 06:37 PM   #3
Rewards Points: 3,818
That looks like a backflow preventer on the hose bib.
take that one off and get a new one,looks like the other piece is on the hose.
Canarywood1 is offline   Reply With Quote
Old 09-10-2012, 07:26 PM   #4
Rewards Points: 14,306
Or just remove both ends and do without it.
And yes that with it is, anti siphon. It acts as a check valve.
Old 09-10-2012, 07:51 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,258
Replace the hose bib.
Coastal South Carolina
Old 09-11-2012, 09:55 AM   #6
Rewards Points: 16
The end was actually an attachment to the hose bibb (I always thought it was part of the hose bibb. So I removed it and now I am able to attach the standard hose I got from HD, but see leaks where it is threaded onto the hose bibb and also through the space between black plastic part and the metal-end. Is this just solvable with teflon tape? Or something else? Thank you.
Old 09-11-2012, 10:12 AM   #7
A new washer in your hose should solve the problem.
Old 09-11-2012, 10:14 AM   #8
Did you put a hose washer in the fitting?
Old 09-11-2012, 10:27 AM   #9
Rewards Points: 340
it's possible that it is the washer, but it's also possible that the problem is a cracked fitting on your hose. cheap hoses use cheap, thin brass fittings that will crack over time, especially with overtightening. the typical symptom is water squirting out at the seam of the fitting (where it turns).
Old 09-12-2012, 09:20 AM   #10
Rewards Points: 254
Drill the set screw out and take the backflow unit off your spout and toss it in the trash. Now connect your hose with a new washer and call it a day.
pwgsx is offline   Reply With Quote
PVC pipe vs Garden Hose ColoradoWildcat Landscaping & Lawn Care 4 08-18-2012 05:37 PM
Has anyone ever used one of those garden hose pressure washer converter wands? jpearson311 Landscaping & Lawn Care 7 07-02-2010 05:05 PM
garden hose water spillage: damage to pipes, huge water bill? cluelessDIYer Plumbing 5 06-26-2010 11:42 AM
Garden Hose calabashfire Plumbing 3 02-07-2007 06:29 AM
Washing machine drain hose morrisp Plumbing 3 09-01-2006 07:24 PM
