Repair Utility Sink In Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-05-2010, 02:25 PM   #1
Repair Utility Sink in Basement
I am in need of some advice on repairing an old cement utility sink in my basement. I'm not sure if it is the trap or something further down the pipe, but the sink will not drain. This is my washing machine runoff drain, so I'd really like to get it working again.
As you can see in the following picture, the old drain fitting is molded into the sink and has rusted out.
How would I determine if it is the trap that is the drainage problem or if it is further down the pipe?
Any advice or how-tos on how to get this sink operational again would be greatly appreciated.
lincolnparkjok is offline   Reply With Quote
Old 10-05-2010, 03:10 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,252
Not sure how to get a new fitting into the sink. An idea- drill around the existing fitting with a masonry drill (many holes), then knock out the old metal fitting. Build a form to hold a new PVC drain and pour concrete around it.
I would bet your clog is in that old drum trap. Unscrew the steel pipe that goes into the tee above the clean out. Install a PVC male adapter into the tee. Run PVC to behind the washer and install a stand pipe with a trap. Install and AAV (air admittance valve) for venting. When you get the concrete tub repaired cut in a sanitary tee in the PVC drain and add a trap for the tub.
Coastal South Carolina
Old 10-06-2010, 08:27 AM   #3
that piece go directly to the 2 strainers that are part of the sink. The only thing thats gonna fix that sink is a sledgehammer . Fiberglass sinks are pretty cheap and easy to install, cut out that old drum trap too
the_man is offline   Reply With Quote
Old 10-06-2010, 08:38 AM   #4
A "Handy Husband"
rjniles's Avatar
A second though. Often those old threaded steel pipe fittings can be a bear to un-thread. If it does not come loose easily, do not horse it too much or you could break something in the stack. Instead use a sawsall to cut the steel pipe about 6" from the tee. Use a Fernco connector to connect to new PVC.
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Old 08-03-2014, 02:29 PM   #5
any idea about making a new stand for one of these old concrete sinks
andi bunton is offline   Reply With Quote
Old 08-04-2014, 06:04 PM   #6
Rewards Points: 2,104
I suggest you use a sludge hammer break that concrete sink into little pieces and replace it with a fiberglass sink. Adapt to your galvanized piping with a transitional coupling (proflex or mission brand) and repipe with A nutted LA style 1.5 inch trap.
After Snaking, Basement floor drain and utility sink still Bubbling & Backup bikermark1 Plumbing 2 07-22-2010 12:14 PM
Adding a utility sink in the basement - draining question sbazzle Plumbing 3 04-24-2010 05:59 PM
Installing Utility Sink newb Plumbing 2 02-05-2010 12:35 AM
utility sink pump installation rcassidy Plumbing 1 02-17-2009 09:34 PM
Do I need a vent on a basement utility tub? skipjack Plumbing 7 09-05-2008 06:57 PM
