Repair Seamed Lead Waste Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-07-2011, 08:14 PM   #1
repair seamed lead waste pipe
Hello all.
I'm wondering if anyone has any ideas about how to repair a break in the seam of a lead waste pipe(for kitchen sink) coming out of the foundation of my house. The break is right next to the concrete foundation wall. Attached are a couple of photos.
Many thanks.
repair seamed lead waste pipe-break-seam-pipe.jpg   repair seamed lead waste pipe-lead-wast-pipe-coming-out-conc-fdn-wall.jpg
tangier101 is offline   Reply With Quote
Old 11-07-2011, 09:04 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I'm assuming you're asking for an answer besides the obvious one. Sometimes the obvious one however difficult it may be is the very best and only course of action. Are you sure it's lead? Orangeburg maybe?
Journeyman Plumber
Old 11-07-2011, 09:04 PM   #3
Plumb or Die!
Rip it out. It's already dug up, what's an hour of jack hammering?
plumber666 is offline   Reply With Quote
Old 11-07-2011, 09:51 PM   #4
Might be Orangeburg
I could be orangeburg - I am not a plumber and was not familiar with this material until just now when I looked it up. The pipe is sticking out of the basement wall so it is not dug up. It is about 3' below a concrete as it leaves the house. The hardware store suggested propoxy20. Any thoughts about this soulution?
Old 11-08-2011, 09:04 AM   #5
Doing it myself
Alan's Avatar
My thoughts about that solution :
Not really a good idea. It's a weak temporary fix at best. You can already see that the pipe is badly deteriorated. Fixing the leaking spot is not going to repair the rest of the pipe that is having trouble. You can't see if there are any more holes in the piping outside that are going to cause roots to invade and block the line off.
What size is the pipe?
Journeyman Plumber
Old 11-08-2011, 09:05 AM   #6
Doing it myself
Alan's Avatar
P.S. Hardware stores often suggest gluing PB piping with CPVC or ABS glue.
Journeyman Plumber
Old 11-08-2011, 09:21 AM   #7
The pipe is 2". I caused the leak by a ham-handed removal of the old clean-out so that I could install a new one. I don't think I would have damaged the pipe beyond the concrete foundation wall. There is quite a bit of gunk on the inside of the pipe. What about an interior sleeve of some sort. The sleeve would not have to be very long to get past the break.
Old 11-08-2011, 12:39 PM   #8
Chicago, IL
Michael Thomas's Avatar
AFAIK, Orangeburg pipe was never widely used as supply plumbing.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 11-08-2011, 07:55 PM   #9
If you can chip out a bit of the foundation wall, you can cut the pipe and attach a mission coupling but thats just postponing the inevitable if there is corrosion on the inside.
wood4d is offline   Reply With Quote
Old 11-08-2011, 08:11 PM   #10
Doing it myself
Alan's Avatar
OP says it's a waste pipe.
Is it actually soft?
Journeyman Plumber
Old 11-09-2011, 06:39 AM   #11
Rewards Points: 1,216
Tangier are you sitting down? You have to replace the pipe in it's entirety there must be a reason you hit it and it split take that as a sign and replace it from where it starts to where it ends, don't forget your ground clamp to the new pipe. Somethings just need to be replaced, I know it sucks and money is tight.
COLDIRON is offline   Reply With Quote
Old 11-09-2011, 09:08 AM   #12
I appreciate all of the feedback - it is clear that the pipe needs to be replaced. Since I am unemployed and short on funds, I have decided to run the kitchen waste pipe through the joist/basement ceiling and connect to the drain pipe on the other side of the house. It will be much much cheaper and I can do it myself. Thanks to all.
Old 11-09-2011, 06:57 PM   #13
Doing it myself
Alan's Avatar
Make sure you do something to appropriately cap/plug the old pipe where it goes through the foundation wall, so that you don't get sewer gas coming back through the line.
Journeyman Plumber
Old 11-09-2011, 08:14 PM   #14
Thank you. I would not have thought of that.
Old 11-10-2011, 03:39 AM   #15
Rewards Points: 562
that looks like galvanized iron pipe rusted out on bottom to me. take a screwdriver and play drums on top side, lead will thud like a wet noodle and actually dent (easy does it),,,iron will ring like a dinner bell
It will be cheaper to replace this line than run clear across house with another IF there us someplace to tie in , even with a no hub coupling.
Million dollar question,,,where does this line lead to???Are you on your own septic or city or central sewer???
Take a hammer and chisel and swing away for small hole to either find end of this pipe or Start of different type,,,like clay etc.
4just1don is offline   Reply With Quote
Tags
repair lead waste pipe
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 09:35 AM
PVC air admittance value and copper waste pipe diy888 Plumbing 2 02-16-2011 07:48 AM
Waste pipe odor in garage? Kirsten Plumbing 3 11-21-2006 12:07 PM
Leaking waste pipe guvlin444 Plumbing 5 09-30-2006 01:36 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
