Repair Or Replace Water Heater? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-30-2014, 09:15 PM   #1
Rewards Points: 79
Repair or replace water heater?
I have a 12-year old Ruud 40-gallon gas water heater. It has started leaking on top where the pressure relief valve attaches. It, as well as the other connections on top, is pretty corroded looking. Is it worth the time to have a plumber come out to see if it can be repaired or should I just plan on replacing the heater?
I feel like if I have a plumber come out who ends up telling me to replace it that will cost more if the plumber replaces it than if I just go to Lowes and Home Depot and buy one, including installation. But, if the plumber can repair it, I would think that might be the cheapest option.
I'm kind of watching my pennies right now since my oldest daughter's wedding is in three weeks and that ain't cheap!
Of course, my wife, who is in full wedding mode right now, just wants it taken care of as quick and as simple as possible.
As always, any advice is appreciated.
bucksone is offline   Reply With Quote
Old 09-30-2014, 09:40 PM   #2
Rewards Points: 580
Repairing it would be a waste of money. It's just a matter of time before it fails. You are better off replacing it.
Dan
djlandkpl is online now   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
jmon (09-30-2014)
Old 09-30-2014, 09:44 PM   #3
Retired Army Veteran
jmon's Avatar
Rewards Points: 4,366
Can you post a picture of it. Thanks.
jmon is online now   Reply With Quote
Old 09-30-2014, 09:51 PM   #4
Rewards Points: 18
12 year old water heater and a trip from the Plumber. JUST bite the bullet and tell him to you a new water heater. Usually the tank is guaranteed for 5 or 6 years and parts one year. It is time. It will save you money and maybe a big mess to cleanup later.
Fred Vaughn is offline   Reply With Quote
Old 10-01-2014, 09:31 AM   #5
Hvac Pro
Rewards Points: 1,974
Replace it. Once he starts shaking the tank to remove the valve it may leak. Also the threads in the tank where the valve attaches are eaten away and may not seal properly with a new one.
Old 10-08-2014, 10:32 AM   #6
Rewards Points: 79
Thanks for all of the advice. We went ahead and replaced the water heater.
Old 10-08-2014, 11:40 AM   #7
Rewards Points: 126
Old items are some time good, But I have suggest that buy new, replace it.
jack45870 is offline   Reply With Quote
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 09:48 PM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 06:40 AM
Replace 15yr old water heater or not? Aquin Plumbing 12 03-28-2008 11:22 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
