Repair Mueller 3/4 Inch Brass Stop And Waste Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-02-2012, 07:44 AM   #1
Question
repair Mueller 3/4 inch Brass Stop and Waste Valve
I have a Mueller 3/4 inch brass stop and waste valve that feeds a fountain. The valve has begun to spray water from the top when I fill the fountain and I have to tap on the top of the valve with the tbar to stop it from leaking when I shut the valve off. I can't see the bottom of the valve without digging it up and removing the valve. Is the valve repairable and is it possible to repair the valve in place?
dadcarter is offline   Reply With Quote
Old 03-02-2012, 07:46 AM   #2
Rewards Points: 152
Some of the old valves had a nut on the bottom that you could tighten and if you're able to tap on the top to stop the leak, that's likely what you have.
burnt03 is offline   Reply With Quote
The Following User Says Thank You to burnt03 For This Useful Post:
dadcarter (03-02-2012)
Old 03-02-2012, 08:04 AM   #3
Any advice on the size of the nut (not the one posting the question, the one on the bottom that I can't see)?
Old 03-02-2012, 08:27 AM   #4
Rewards Points: 152
I'm afraid I don't know. Shouldn't take too much torque though... if you can reach in with a crescent wrench, that should do it.
Tags
mueller , plumbing , repair , valve
Gate Valves or Stop and Waste Valves Rich Plumbing 5 03-03-2014 02:29 PM
anti freezing stop and waste valve leaks James Parsons Plumbing 1 10-07-2007 02:11 PM
