Repair Coupler - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2013, 09:16 AM   #1
Rewards Points: 236
repair coupler
how is a repair coupler glued ? seems to me that there is a chance of not getting a solid seal. as you can't put glue on the inside of the fitting.
Fix'n it is offline   Reply With Quote
Old 02-24-2013, 09:24 AM   #2
Rewards Points: 14,026
Not going to happen, cut it out and replace.
I'd use 2, repair couplings and a new piece of pipe in the middle.
A repair coupling has not ridge in the middle so it can slip right over the pipe.
I hold it up and mark the pipe so I know it's going to be in the right place when glued.
The repair coupling I'm talking about is PVC not just a hubless connector.
Old 02-24-2013, 09:42 AM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 996
Different glues for slower fuse time, do it all the time i will only use a rubber coupling when i have no choice or its temporary repair, i made my self a special little tool to work the coupling fast over pvc, not easy to do but certainly not impossible.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-24-2013, 10:00 AM   #4
Rewards Points: 236
ahh, gotcha. its probably not the prettiest of a joint, ay ?
Old 02-24-2013, 10:03 AM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 996
not at all but it works and seals
The Following User Says Thank You to Javiles For This Useful Post:
Fix'n it (02-24-2013)
Old 02-24-2013, 10:59 AM   #6
Roofmaster
Rewards Points: 2,210
What is the repair?
Old 02-24-2013, 02:07 PM   #7
Rewards Points: 236
Originally Posted by jagans View Post
What is the repair?
there isn't one. i was just wonderin while i was fitting my pipes.
can you tell me about the slow dry stuff ? any issues with it ? i think i need to use this, stead of what i have now.
drywall repair raspy Drywall & Plaster 6 07-30-2012 08:58 PM
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 06:42 AM
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 12:42 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
