-   -   repair coupler (http://www.diychatroom.com/f7/repair-coupler-172815/)
Fix'n it 02-24-2013 09:16 AM
repair coupler
how is a repair coupler glued ? seems to me that there is a chance of not getting a solid seal. as you can't put glue on the inside of the fitting.
joecaption 02-24-2013 09:24 AM
Not going to happen, cut it out and replace.
I'd use 2, repair couplings and a new piece of pipe in the middle.
A repair coupling has not ridge in the middle so it can slip right over the pipe.
I hold it up and mark the pipe so I know it's going to be in the right place when glued.
The repair coupling I'm talking about is PVC not just a hubless connector.
Javiles 02-24-2013 09:42 AM
Different glues for slower fuse time, do it all the time i will only use a rubber coupling when i have no choice or its temporary repair, i made my self a special little tool to work the coupling fast over pvc, not easy to do but certainly not impossible.
Fix'n it 02-24-2013 10:00 AM
ahh, gotcha. its probably not the prettiest of a joint, ay ?
Javiles 02-24-2013 10:03 AM
not at all but it works and seals :thumbup:
jagans 02-24-2013 10:59 AM
What is the repair?
Fix'n it 02-24-2013 02:07 PM
Originally Posted by jagans (Post 1123794)
What is the repair?
there isn't one. i was just wonderin while i was fitting my pipes.
can you tell me about the slow dry stuff ? any issues with it ? i think i need to use this, stead of what i have now.
