Old 06-02-2008, 02:59 AM   #1
Is this a reoccurring clog in the toilet waste line?
I have a toilet that over the years frequently gets clogged and leaks around the base every time.
Is this a problem in the waste line under the toilet, backing up the water so the wax seal can't handle it? We've replaced the toilet, and here again it gets clogged and leaks around the base.
What would be the best fix if that is the case?
darsunt is offline   Reply With Quote
Old 06-02-2008, 06:52 AM   #2
Underground Techie
sevver's Avatar
Sounds like it is in your waste line. I would snake it and camera it. If you are curious camera it first, then fix it, then camera it again. Are your lines buried under a slab, or is there a basement or crawl?
sevver is offline   Reply With Quote
Old 06-02-2008, 12:11 PM   #3
They are buried under a slab, I believe.
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Need opinion - Need help - I believe my toilet was not installed properly rdlegacy Plumbing 9 05-06-2008 06:03 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
