#1 |
Reoccuring slow tub drain
I have a slow drain in my tub. I use liquid drain cleaners, that work temporarily, but the drain re-clogs within a few days. All the other drains in the house (kitchen, bathroom sink, washer) are fine.
All the plumbing is accessible in the basement. Do I replace the trap? Is there something to keep the drain open? Please help. Last edited by jmorc2003; 10-18-2012 at 09:03 PM. |
#2 |
show picture of piping.....
#3 | |
Reoccuring slow tub drainQuote:
#4 |
Since it's a glued on trap your going to have to snake it from the drain.
Alway try a drain snake before using dangerous, castic chemicals. At some point consider getting rid of all that old steep pipe. |
#5 | |
| The Following User Says Thank You to ben's plumbing For This Useful Post: | oh'mike (10-20-2012) |
#6 | |
I guess what I'm asking is, is the reoccurring because of a clog (hair and such), or is it years and years of build up. Last edited by jmorc2003; 10-19-2012 at 02:29 PM. |
#7 | |
#8 |
Likely hair in the pipe. I've had good luck running a small snake down tub overflow and getting a wad out that way.
May be the problem; may not but a bit easier than replacing the mains... |
#9 |
Update: I tried plunging like crazy but that actually made it worse, i was stuck with about three inches of water that wouldnt go down, as in stuck, not just slow. so i snaked the drain today (bought one for $15 at hd) and boy did it do the trick. You should have seen, and smelled, the glob of hair and gunk I pulled out. Water drained immediately. Woohoo!
Using the snake was very easy too. I took out the overflow and stopper assembly, fed the snake down the overflow, twists and turns were very easy to manage, and there you have it. |
| The Following 3 Users Say Thank You to jmorc2003 For This Useful Post: |
| Display Modes | |
| Slow drain fast drain | knotquiteawake | Plumbing | 7 | 06-16-2012 06:08 PM |
| slow upstairs sink drain | mxcrazy | Plumbing | 3 | 07-23-2011 11:16 PM |
| Furnace leak while running AC unit | lbartowski | HVAC | 3 | 09-18-2009 02:46 PM |
| washer drain is draing slow | mrmordun | Plumbing | 13 | 03-08-2009 11:45 PM |
| Condensor drain | Captflx | HVAC | 6 | 08-17-2008 11:19 AM |
