Renter Seeking Advice For Sealing Around Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-07-2010, 07:29 PM   #1
Newbie; Clueless
Renter seeking advice for sealing around pipes
I'm renting a ground level "apartment" in a split up home with a dank, scary basement. I don't have too many complaints but there is a strange odor in the kitchen and bathroom. It is a sort of acrid, varnish-like smell.
I have gaps between the woodwork and virtually every pipe in the place. Even if the odor isn't coming from the basement, I'd like to pest-proof these sites and would appreciate the expertise of the community. Here are my problem spots:
The first image is under the bathroom sink. There is about a 1/2-inch gap between the pipe and the mysterious dark. The second image is a valve. It wobbles to the touch and I would prefer to seal it if possible. I will make another post for other problem spots.
How would you seal these areas for pests and odors?
Renter seeking advice for sealing around pipes-picture-video-091.jpg   Renter seeking advice for sealing around pipes-picture-video-093.jpg
bookryder is offline   Reply With Quote
Old 07-07-2010, 07:36 PM   #2
Newbie; Clueless
Now we move on to the kitchen. As you can see, there was some previous water damage. The drywall is bone dry but fragile. There is a large hole for an electrical cord (garbage disposal?), that is 2.5 inches at the widest. There is some additional plumbing suffering from the cracking, but the gaps are mostly less than an inch away from the pipe.
What would you use to seal these spaces from odors and pests?
Renter seeking advice for sealing around pipes-picture-video-094.jpg   Renter seeking advice for sealing around pipes-picture-video-095.jpg   Renter seeking advice for sealing around pipes-picture-video-096.jpg
Old 07-07-2010, 07:37 PM   #3
DIY staff
Rewards Points: 7,174
I'd suggest clear painters caulk For the small gaps---Great stuff blue can for the larger ones.
Old 07-07-2010, 08:26 PM   #4
Rewards Points: 1,088
Low expansion spray foam?
handy man88 is offline   Reply With Quote
Old 07-08-2010, 10:31 PM   #5
DIY staff
Low expansion-yes--less likely to move the piping--easier to remove later.
Seeking advice for wiring in hot-tub. YerDugliness Electrical 47 03-18-2012 12:35 AM
Seeking advice on severe rust buildup issue. YerDugliness Plumbing 2 05-07-2010 07:02 AM
Vent Noise - Rubbing Wood; Seeking Advice steveo_1978 Plumbing 4 01-22-2010 11:26 PM
Replacing pipes in bathroom, need advice Steelmesh Plumbing 7 11-04-2008 12:30 PM
Seeking Advice On Building Contract RichardE General DIY Discussions 5 04-25-2007 02:19 AM
