Removing Wirsbo PEX Ring - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-11-2012, 11:00 PM   #1
Rewards Points: 518
Removing Wirsbo PEX ring
Anyone know how to remove a Wirsbo/Uponor PEX expansion ring without damaging a copper manifold port or fittings?
n0c7 is offline   Reply With Quote
Old 01-12-2012, 05:56 PM   #2
Rewards Points: 582
Iuse a new razor in my utility knife...be careful keep it angled away from fitting.....works for me all the time...
Old 01-12-2012, 07:20 PM   #3
Civil Engineer
Rewards Points: 4,700
There was a post about 6 months ago on this topic, absolutely brilliant suggestion that I have used many times since. The outside ring can be cut off with a knife as previously suggested. DO NOT cut the PEX pipe off the fitting with a knife if you plan to reuse the fitting, you will almost certainly nick the fitting and it will leak.
The suggestion (I would love to credit it, can't remember who suggested it) was to heat the PEX tubing lightly with a propane torch until it turns clear, then pull it off the fitting. Works like a charm, you can reuse the fitting, works with brass and plastic fittings (be a little more careful with the plastic fittings).
The Following User Says Thank You to Daniel Holzman For This Useful Post:
ben's plumbing (01-13-2012)
Old 01-13-2012, 09:42 PM   #4
Rewards Points: 518
So heat it after you've cut off the ring?
Removing compression ring? ruzz Plumbing 30 10-01-2011 06:14 PM
Using crimp ring on Wirsbo simonb Plumbing 0 03-21-2010 01:12 PM
closet ring flange help/explaination eyeglass Plumbing 2 09-09-2009 06:35 PM
Wax Toilet Ring Question cabinetman Plumbing 2 05-31-2009 10:12 AM
Replace tub's drain ring without removing tub? BradG Plumbing 12 03-17-2009 11:21 AM
