Removing Waste Plug From Tub Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-13-2011, 06:52 PM   #1
Rewards Points: 682
Removing waste plug from tub drain
I'm looking at replacing a drain assembly for a shower/tub. I've heard the waste plug for the drain is particularly hard to remove. What is that special tool they use to remove it? And how likely is the waste plug to be frozen, needing the saws all solution?
Also the P trap probably needs replacing. How tough is it to get off that big iron pipe and should I just use pipe dope on the threads?
darsunt is offline   Reply With Quote
Old 01-13-2011, 07:06 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 566
These work if the cross in the bottom of the drain doesn't break out.
When I replace the traps I cut of the galv. pipe downstream from the trap and adapt to plastic.
http://www.amazon.com/Superior-6020-.../dp/B000AO193S
Leaking main drain clean out plug. dakornblum Plumbing 2 10-26-2010 06:20 AM
Removing washing machine drain from septic 12172003A Plumbing 2 07-25-2009 05:32 PM
advice in removing plastic drain valve from water heater darsunt Plumbing 1 06-15-2009 04:30 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
External Waste Water Drain alangan Plumbing 1 08-11-2005 07:42 AM
