Removing Washing Machine Drain From Septic - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-25-2009, 09:24 AM   #1
Removing washing machine drain from septic
We are trying to remove out washing machine drain line from out septic tank line. We were thinking of a dry bed drain. What is the best material to use??
12172003A is offline   Reply With Quote
Old 07-25-2009, 12:43 PM   #2
Rewards Points: 1,494
They make a perforated plastic dry well (dry bed) liner to put in the hole you dug. An alternative is bricks laid not without mortar with a prefabricated concrete or steel lid. Then just about anything (PVC pipe suggested) can be used to re-route the washing machine drain line to that.
Some city codes may prohibit the use of a dry well for anything other than plain water such as rain water.
You really should not need to re-route your washing machine drainage from your septic tank unless you are experiencing septic system problems.
Old 07-25-2009, 05:32 PM   #3
Long-Time DIYer
Mike Swearingen's Avatar
Check with your Heatlh Department before doing this. It's illegal in many places.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Trap and washing machine safety drain pan wildbilly Plumbing 18 03-05-2013 07:08 PM
Washing Machine Drain handy man88 Plumbing 17 12-23-2012 07:16 AM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 08:25 PM
Washing machine drain hose morrisp Plumbing 3 09-01-2006 07:24 PM
