Removing Very Old Kitchen Faucet. - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-13-2011, 07:18 AM   #1
removing very old kitchen faucet.
the screw that holds the faucet on - it is old and rusted. Want to replace the faucet but cannot get the bolt off - very tight area to work on. Tried encasing the screw in W-D - any ideas
Eric Maurer is offline   Reply With Quote
Old 02-13-2011, 07:36 AM   #2
DIY staff
Rewards Points: 7,174
Screw? Moen faucet? Could you clip that off with a Dremel with a grinding wheel?
Drill around the screw and break the plate off?
Picture would help if you can get a shot under there---Mike---
Old 02-13-2011, 01:19 PM   #3
Homerepairguy's Avatar
Rewards Points: 998
Since you need to disconnect the plumbing to the faucets anyway, maybe disconnect the trap and remove the entire sink and faucets. Then it would be much easier to remove the frozen faucet. Sounds like it's an old installation so new caulking around the sink might be a good thing.
HRG
Homerepairguy is offline   Reply With Quote
Old 02-13-2011, 01:21 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 494
You wouldn't happen to be Eric M from Cleveland would you?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Pulsating Kitchen Faucet Hemingway Plumbing 2 08-29-2010 03:03 PM
Good brand of kitchen faucet for an old home Stevoreno Plumbing 17 05-23-2010 06:33 PM
Kitchen Faucet + shower diverter: Need help xtrips Plumbing 1 02-14-2010 03:27 PM
Low hot water pressure on kitchen faucet Ultrarunner2017 Plumbing 7 12-19-2008 09:49 AM
Question about a kitchen faucet skwpt Plumbing 10 10-11-2007 06:54 PM
